Thoughts on an 02
Old Nov 18, 2012 | 12:50 AM
Stebs's Avatar
Stebs
Thoughts on an 02
Alright brothers (and sisters), I need your opinion. My boss is thinking of selling his 02 limited ex with a 7.3. It is just shy of 400k miles. The last 100k or so has been towing heavy (12,000 to 14,000lbs). this truck is mostly hightway miles. Oil has been religiously changed every 5,000 miles, and had to have the oil cooler replaced in it around the 100k mile mark as it failed and pumped oil into the coolant (luckily not the other way around). Wheel bearings were replaced recently as well. Other than the oil cooler and a few alternators, starters, and batteries, everything on the truck is what was on it from the factory.
Last I checked, it has 4 codes set. 1 for glow plug #3, 1 for the GPCM not communicating, 1 for IPR not controllable (fairly sure on this one), and 1 for something with the waste gate (fail steady state?) I think the last 2 are from the superchips programmer that is on the truck.
If I were to buy it, I would need to replace the trans soon as it is starting to slip. I think it would also be wise to replace the injectors as well, and I believe the fuel bowl is leaking as well.
So the questions I have are, what do you think this truck is worth, and if I were to buy it (its a possibility), what else do you think I should do to it?
Old Nov 18, 2012 | 01:05 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Okay, here's my two cents... The codes are all fixable for pretty cheap. Glow plugs are easy, as is the GPCM... I know for a fact these trucks are beasts but at 400 plus you might be asking for trouble. Not saying it's not worth looking into but if it's gonna be you DD then I'm pretty sure you can do better. Although I don't know the price yet so how would I know anything here... Forget what I said and do what you want.
Old Nov 18, 2012 | 01:18 AM
Skip1970's Avatar
Skip1970
it all comes down to price
Old Nov 18, 2012 | 01:32 AM
Monsta's Avatar
Monsta
Sit. Stay.
That's what he's asking fellas.
Originally Posted by stebs
So the questions I have are, what do you think this truck is worth...
I would probably only pay between $3000-4500 depending on overall condition, A good tranny is gonna set you back $3500.
Old Nov 18, 2012 | 01:35 AM
Skip1970's Avatar
Skip1970
3k is about what i would consider fair.
Old Nov 18, 2012 | 01:49 AM
TXtinct's Avatar
TXtinct
Well there you go. Ask and you shall get answers, I think that's the saying...
Old Nov 18, 2012 | 02:07 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I also agree with $3000
Old Nov 18, 2012 | 11:25 AM
XbigXredX's Avatar
XbigXredX
There was one locally with 350k on it and they were asking $3500. A few months back there was another locally with just about 400k at $4200. I'm in PA and by locally I mean NY NJ PA as that is where I look when looking.
Old Nov 18, 2012 | 11:34 AM
1 Excursion camper's Avatar
1 Excursion camper
Is this X clean like it has only 50k miles or is it rough like it has been used on construction sites and no one ever cleaned off their muddy boots or equipment?
That alone to me is a $3k dollar difference!
Old Nov 18, 2012 | 08:44 PM
Stebs's Avatar
Stebs
Its clean and very well taken care of, I'm usually the one that cleans it. As far as I know, theres only 1 dent where he accidentally jack-knifed a trailer too much. I just got done washing and polishing it the other day, shines like its brand new (its black by the way). He drives it easy, never mashes it and he tries to keep it under 3k rpm, and doesnt use the cruise control when pulling trailers to keep it from downshifting and winding up real tight.
He figured it'd be worth 8500, i figured 10k just cuz its a 7.3 and lots of people are scared to even touch the 6.0's, but obviously i've completely lost my mind this week.
Old Nov 18, 2012 | 08:56 PM
BigPigDaddy's Avatar
BigPigDaddy
True.
Does you boss think it is worth over $8K when it needs a trans?
Old Nov 18, 2012 | 09:05 PM
Stebs's Avatar
Stebs
Do these help any? they were taken 2 different days.
Old Nov 18, 2012 | 09:07 PM
Stebs's Avatar
Stebs
Originally Posted by BigPigDaddy
True.
I think it needs one, he doesnt think it does...
Old Nov 18, 2012 | 09:18 PM
BigPigDaddy
Will he pay for the trans if it needs one after you buy the X?
Old Nov 18, 2012 | 09:28 PM
1 Excursion camper
Even if it needed a trans a nice 7.3 diesel X w/high miles is worth at least $5k
And yes from the pics the X looks very clean!
