Sponsored by: Auxito
Quick Recommendations for Tune up
Old Nov 14, 2012 | 06:00 PM
ech0sh4y's Avatar
ech0sh4y
Hey guys trying to solve the rough idle issues. I'm going to be doing a tune as I'm not sure when the last time the plugs have been changed... wish me luck!
Here is a basic list thus far:
- 8 plugs
- 8 COP boots
- PCV
- IAC valve
- Oil filter/fluid change
- Air filter
- Check coolant
- Transmission fluid/filter change
- Front/rear diff fluid
- Transfer case fluid
* would like to change the power steering and brake line fluid but probably won't get to that
I'm noticing a rough idle but it doesn't seem to effect drive ability at all (no misses), only when idling. It's really annoying.
Also I'm getting a pretty loud knocking way down low. I don't think it's the typical piston knock that some have experienced... i hope it's not something bad. But again i only really hear that at idle as well.
Lastly I have the exhaust manifold gasket leaking. I was wondering do shorty headers make a difference? If I'm going to to replace the gasket might as well upgrade! I already have a flow master cat back.
This is all on a 2003 5.4 with 120k miles.
Thanks,
Brian
Old Nov 14, 2012 | 07:27 PM
kbsupercrew's Avatar
kbsupercrew
clean maf with maf cleaner, fuel filter, and might as well change the upstream 02 sensors when you fix the exhaust leak, shorty headers will make little difference, I only noticed a very little more pull in the upper rpms only, thats what it seems like anyway
Old Nov 15, 2012 | 01:08 AM
ech0sh4y's Avatar
ech0sh4y
Did the shorties give you a bit more noise? The 50 series is pretty quite for my taste.
Old Nov 15, 2012 | 06:27 AM
kbsupercrew
Not really, at idle they sounded like stock manifolds, at the upper rpms you could hear them alittle, here is my mod link, headers and catback gibson super truck
https://www.ford-trucks.com/forums/1...-possible.html
Old Nov 17, 2012 | 01:38 PM
ech0sh4y's Avatar
ech0sh4y
Alright thanks for the reply. Looks like a not-so fun job... I'll just start with the tune up!
kindle98
3.8 & 4.2L V6
Jun 10, 2015 09:09 PM
neilr
Escape & Escape Hybrid
24
Oct 11, 2011 04:16 PM
towmater
1983 - 2012 Ranger & B-Series
Feb 18, 2007 04:27 PM
pitrow
Sep 15, 2005 10:36 PM
ExpoBoi99
Mar 12, 2004 08:51 PM
