remove lightbulb
Old Nov 14, 2012 | 12:10 AM
1969furd's Avatar
1969furd
remove lightbulb
i need to know if i can remove the light bulb for the flat tire light, it has gotten colder here in Phoenix, AZ and i dont need the damn bulb on. can i remove the bulb and call it good?.
Old Nov 14, 2012 | 05:36 AM
danorules's Avatar
danorules
Why not inflate the tire? That will turn the light off also
Old Nov 14, 2012 | 05:52 AM
1969furd's Avatar
1969furd
it should have to go off with only 2-3 lbs low, i have driven long enuf without this modern crap telling me when to inflate my tires
Old Nov 14, 2012 | 06:25 AM
shorebird's Avatar
shorebird
I would assume that you can pull the dash and remove the bulb then reassemble the dash and hope that there are no squeaks that develop.
Or you can simply PUT SOME AIR IN YOUR TIRES!
Old Nov 14, 2012 | 06:55 AM
MCDavis's Avatar
MCDavis
I agree, sure is a lot of work to pull the dash...might be easier to inflate the tires with a hand pump for a bicycle rather than pulling the dash.
I'm with these guys...just inflate the tires.
Old Nov 16, 2012 | 01:00 AM
DieselBeast01's Avatar
DieselBeast01
Agreed... why on earth would remove the bulb when you can just pump up the tires at home or if you don't have a compressor stop at any gas station and pay 25 cents to use their air pump.
Old Nov 16, 2012 | 01:06 AM
khadma's Avatar
khadma
Carpenter Local 745
Cover the icon with black electrical tape as viewed from
Driving position, a happy face sticker would work too.
Putting air in the tire takes all the fun out of it.
Air in the tire, geez.
R&T Babich
Oct 24, 2018 11:36 PM
CharlyG
Oct 14, 2016 11:07 AM
Greenheadkiller
1997 - 2003 F150
Jul 27, 2010 05:43 PM
R. J. Pearson
1997 - 2003 F150
Aug 19, 2002 05:44 AM
