Sponsored by: Auxito
Replacing front marker light bulbs
Old Nov 26, 1999 | 08:05 PM
R. J. Pearson
Guest
Posts: n/a
I have a 1997 F350 and need to replace a bulb in the front marker light (directly above the head light), but I have not been able find a way to get to the bulb. Has anyone ever replaced these bulbs?
Old Aug 9, 2002 | 10:30 PM
copeina's Avatar
copeina
I drove one of these as a delivery wagon a few years back. Everything seemed to be the same as my F150, so my first suggestion would be to open the hood and see if it will twist out from behind.
Hope that helps (a bit),
/Kris
Old Aug 18, 2002 | 09:46 PM
bosshoss's Avatar
bosshoss
Hey how you doing. I know a lot better if you did not have to change that bulb right. Its been awhile since i had to do one of those. But if i remember, the headlight assy, must come out for the MARKER LIGHT. Once you remove the clips from the back of the headlight assy. Remove the two screws at the top of the light assy in the grill. THERE ARE 2 NUTS that hold the whole thing in place at the rear bottom of the light assy. I think they are 10mm nuts. You should be able to remove the light assy to get to the marker light. If it is on the battery side, remove the battery tray for better access. I hope this helps. If I can, i will look it up in the service book. GOOD LUCK.
Dave Powell
Old Aug 19, 2002 | 05:44 AM
m3810's Avatar
m3810
BCM
Oct 19, 2019 11:26 AM
Andercomm
Escape & Escape Hybrid
Oct 14, 2015 07:21 PM
Turx
Feb 17, 2011 07:12 PM
PAPPYBALL
Aug 26, 2009 11:40 PM
Aerocook
Aerostar
Jun 28, 2006 11:09 AM
