another BB head question..
Old Nov 13, 2012 | 09:52 PM
Bulldawg1081's Avatar
Bulldawg1081
ive got a freshly built 429 in my 87 ford f350 4x4 i believe its a 1973 model which has the horrible d3ve heads.. i was wondering if the later 94 and newer 460 heads would be better or the old style '71 and older heads?
Old Nov 14, 2012 | 06:33 AM
DIYiT's Avatar
DIYiT
If you plan to keep it carb'd and use the carb style intake and exhaust manifold/header, you'll want to stick with the pre '87 carb'd heads. The intake and exhaust ports are in different positions on the EFI heads so they are not compatible with the earlier 460 top end.
If you want to go EFI, there are the '87-91 E7TE heads, and the '92-96/97 F3TE heads. From what I've learned from Mad Porter at 460ford.com, The E7TE heads have better flow potential when ported due to larger intake ports, but the F3TE heads are optimized for better swirl and a better quench area.
Old Nov 14, 2012 | 06:04 PM
Bulldawg1081
thankyou sir...ive read since making this post that the d3 heads with a little machine work perform really well
mcculloughrp
29
Jan 10, 2025 11:42 AM
gearhed1971
Mar 9, 2010 08:07 AM
TX460Bronco
13
Jul 20, 2006 08:16 PM
black460
16
Dec 6, 2004 05:50 PM
oricle
Oct 23, 2004 10:28 PM
