Modular V10 (6.8l)
missfire help please!!!
Old Nov 16, 2012 | 12:09 AM
creeper113's Avatar
creeper113
Alright now I tried for an hour to figure out how to test the pressure then spent another hour looking for something on here, no cigar. Im used to the old convenient schrader valve on the rail. I searched for one on this baby and I am having no luck. So can somebody clue me in as to how to go about testing the fuel pressure on her? Thanks
Old Nov 16, 2012 | 12:11 AM
creeper113's Avatar
creeper113
Originally Posted by jh818
I assume you did replace that broken CPS, right? Connector didn't get bent?
And yes sir I did. I put the CPS off the old motor on the new one.
Old Nov 16, 2012 | 05:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
On my 2001, it's on the rail, passenger side, way in the back.
Old Nov 16, 2012 | 07:21 AM
BigPigDaddy's Avatar
BigPigDaddy
... so I got a salvage motor complete from automotix with 32 thousand on it. Somewhere in shipping the engine was dumped over on the front (from what I can figure out from the scuffs and broken camshaft sensor) and it’s had oil run throughout the intake.
The skeptic in me is wondering if that engine was damaged in a wreck while still in the original vehicle, and not when being shipped to you. What you thought was shipping damage could have been crash damage and the oil in the intake could be from a rollover crash.
If it was damaged in a wreck while running, are there any sensors besides the camshaft sensor that could be causing your problems?
Old Nov 16, 2012 | 10:04 AM
creeper113's Avatar
creeper113
Actually I'm positive that it was damaged during shipping. just the way that the pallet was damaged and everything. I did take the other other sensors an and everything from the from the original motor because I knew that it was all in working order. And on the fuel real there's definitely no port. I even checked the assembly that's not in the truck. So can anyone help me out testing the fuel pressure?
Old Nov 16, 2012 | 10:30 AM
krewat's Avatar
krewat
I think they make a test fitting that is installed between the fuel line and the rail. What a pain...
Old Nov 16, 2012 | 10:37 AM
BroncoRN's Avatar
BroncoRN
Do you have coils from previous engine?
Old Nov 16, 2012 | 10:54 AM
creeper113's Avatar
creeper113
Thanks Krewat, I was thinking that's what it was gonna be. Ya im running the coils from previous, new boots.
Old Nov 16, 2012 | 12:01 PM
BroncoRN's Avatar
BroncoRN
I would say get some new coils for cylinders that misfired. Have you reset computer? What codes SPECIFICALLY were thrown?
Old Nov 16, 2012 | 03:14 PM
creeper113's Avatar
creeper113
Well I got ahold Ford and they knew nothing of any kind of fitting, they said they just used the scan tool. So I built my own fitting and tested just after the fuel filter. It's got 32 PSI at idle and 40 PSI at wide open. Why I was under there I noticed a little oil the outside of clip on the PCV valve, drivers valve cover. I pulled it off at the throttle body and it was slightly damp with oil inside the hose, think this is connected? As far as the COPs are concerned I don't think they are the issue. I don't see how I could lose like 9 of them in the snap of the finger. The codes were all missfire codes. Whats next here?
Old Nov 17, 2012 | 02:19 PM
creeper113's Avatar
creeper113
Any other ideas fellas?
Old Nov 17, 2012 | 02:36 PM
BroncoRN's Avatar
BroncoRN
Have you cleaned injectors? Cleaned MAF? Reset computer? Cleaned throttle body?
Old Nov 17, 2012 | 02:44 PM
  #28
creeper113's Avatar
creeper113
Rest computer, yes. Cleaned MAF, yes. Cleaned throttle body when engine was dropped in a few days prior. And ran a tank of sea foam through injectors. Thats my best version of cleaning them.
Old Nov 17, 2012 | 03:52 PM
  #29
BroncoRN's Avatar
BroncoRN
Might pull an injector and see if screen in there is clogged
Old Nov 17, 2012 | 05:24 PM
  #30
Treker58's Avatar
Treker58
Is this fuel rail, injectors, from your old motor or did they come with the engine, you may want to get this
Ford 6 8L V10 Fuel Injector Service Repair Kit O Rings Seals Filters | eBay
I'll tell you that if this motor sat with any kind fuel in it the varnish build up is just that varnish. When I redid the carbs on our boat that the prior owner did not run very often the old fuel gets so hard that when you clean it out it's almost like plastic chips. How many of the cylinders are reporting misfires
