Compression tester
Old Feb 6, 2013 | 05:22 PM
Methodical_1's Avatar
Methodical_1
Originally Posted by whittier97370
mine is a 4.6L not 5.4L. Not sure that makes a big difference in the triton engines though. However, local Ford dealer did not call me back today. Guess they don't want to earn my business so I will look elsewhere or do it myself.
Whittier here's a couple videos showing how to do a leak down test just in case you decide to do it on your own. As long as you have the correct parts, it's pretty easy. You can build the leak down tester for cheap (I like the ease of use of the gauge in the 2nd video. These videos came from you tube and there's plenty more over there. Go ahead and do it yourself. You should be able to get to most plugs without too much issue. You can get to 1 and 2 really easy as you already know, 3 and 4 is a pain, but if you remove the fuel rail they are easier to access and 5-8 should be pretty easy, again you may have to remove the fuel line, but no big deal removing it.
However, since you know you have to pull the passenger side heads, you may as well just pull them and take it to the machine shop and let them do all the testing, milling etc Put your time and energy into removing the head(s) , hell you may as well yank them both. No need to waste your money and time with the dealership as you already know there's a problem with at least the passenger side head. Save your money and time. Just One Man's Opinion.
Other helpful information
Old Feb 9, 2013 | 09:09 PM
whittier97370's Avatar
whittier97370
thanks. I have not decided what exactly I am going to do just yet. Since I don't have a garage this is going to wait until probably April or May (since it rains here in Oregon all the freaking time). I basically have 3 options at this point. Yank the heads and have a local machine shop rebuild them. Find some remanufactured heads and swap them out, or since it has 158K I may just swap the motor with a remanufactured one.
Oldanvilyoungsmith
Jun 4, 2023 02:02 PM
joec380
Feb 17, 2012 12:17 PM
thedieselkid
15
May 20, 2011 07:47 AM
custom_nirvana
Jul 23, 2009 08:23 PM
CManT1914
1997 - 2003 F150
25
Aug 19, 2008 03:42 PM
