390 rebuild
Old Nov 13, 2012 | 02:52 PM
Lostownloser's Avatar
Lostownloser
390 rebuild
Rebuilding my 76 390. I already have a Holley 4 brl carb intake manifold and air intake. I'm putting in headers and exhaust a different cam and a different gear ratio. Can any one give me any suggestions on what cam I should get with what gear ratio? It's a standard 4 speed I do drive it on the freeway and absolutely no towing. I just want some muscle on the streets. Also is it worth upgrading the fuel pump? Thank you for any suggestions you might have.
Old Nov 13, 2012 | 06:34 PM
Riderman's Avatar
Riderman
I ditched the 4:10's and went 3:73. It still has giddy up and go but you can open it up a little and pass someone on the freeway without redlining the tach.
I have a mildly built 390 and have never had an issue with the stock fuel pump. The only problem I had was too much pressure for a Eldelbrock carb and had to install a regulator. But I dont truck pull or race either like some here.
Old Nov 13, 2012 | 07:40 PM
HIO Silver's Avatar
HIO Silver
Refer to the last post in tech threads hyperlink compilation. There's a couple of links for FE builds... the articles, IIRC, have some cam recommendations for street/strip applications.
earnie
Sep 12, 2009 06:27 PM
DJOHNSTON78
24
Dec 20, 2007 11:43 PM
TKKTommyboy
Mar 7, 2006 02:28 PM
1970Custom
Oct 16, 2005 03:00 PM
linrick1
Nov 4, 2004 06:41 PM
