ATF DIPSTICK
Old Nov 13, 2012 | 09:05 AM
auden's Avatar
auden
ATF DIPSTICK
The dipstick tube on my 2001 F-350 automatic trans is flopping around like a wet noodle after a repair job at a shop where they had to remove it. Checking underneath shows the tube just sitting on it's O-ring in the pipe that goes into tranny. I tried to push it down without using too much force but it didn't seat. Because I break most things I touch I thought enquiring here before I push too hard might yield some helpful hints. Thanks
Old Nov 13, 2012 | 09:27 AM
mueckster's Avatar
mueckster
Is the tube bracket bolted down correctly under the middle bellhousing bolt on the passenger side? The bracket is held to the tube with a few spot welds that could have broken loose.
Old Nov 13, 2012 | 10:21 AM
Ford79's Avatar
Ford79
It is either not bolted to the trans bolt, the bracket is broken off the tune or the tube itdelf is broken.
SSG VA BEACH
1997 - 2003 F150
May 6, 2015 04:04 PM
Riggs13
Jun 10, 2013 11:38 PM
Ford79
Jun 22, 2008 01:45 PM
superduty4x4
Mar 16, 2008 06:58 PM
gdw3138
Bronco II
Jun 3, 2007 06:21 AM
