I Just received my edge evolution tuner for my pickup. Upon "successfully" applying the chip to the vehicle; now my pickup, despite any throttle position, my pickup cannot even pull 1,000 RPMs. Does anyone know what might be causing this?
As a side note, the cruise control has not worked since i bought the vehicle in September 2012. There is power to the switches on the steering wheel. It throws a P0360 circuit malfunction code.
I just googled P0563 and read about the high system voltage, it says the computer will disable many of the sensors in order to protect the hardware if it detects the voltage is over 17.1 volts.
