1996 7.3L tuner caused issues
Old 11-12-2012, 08:34 PM
olso2454's Avatar
olso2454
olso2454 is offline
I Just received my edge evolution tuner for my pickup. Upon "successfully" applying the chip to the vehicle; now my pickup, despite any throttle position, my pickup cannot even pull 1,000 RPMs. Does anyone know what might be causing this?
As a side note, the cruise control has not worked since i bought the vehicle in September 2012. There is power to the switches on the steering wheel. It throws a P0360 circuit malfunction code.
Thanks for any and all help!!!
Old 11-12-2012, 09:39 PM
Spktyr's Avatar
Spktyr
Spktyr is offline
What happens if you remove the chip and set everything back to stock?
Old 11-12-2012, 09:42 PM
olso2454's Avatar
olso2454
olso2454 is offline
Returning it back to stock doesn't change anything I still am stuck under 1,000 RPMs
Old 11-12-2012, 10:39 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Is P0360 the only code being thrown?
Old 11-13-2012, 04:22 PM
olso2454's Avatar
olso2454
olso2454 is offline
I just checked for more codes and these are the two that I am given:
P0563- System Voltage High
P0603- Internal Control Module Keep Alive Memory error
Thanks for the help!!
Old 11-13-2012, 04:39 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I just googled P0563 and read about the high system voltage, it says the computer will disable many of the sensors in order to protect the hardware if it detects the voltage is over 17.1 volts.
You should google those two error codes....
Slap59
03-14-2013 03:54 PM
Joelong258
10-07-2010 06:33 PM
nedaclu
06-21-2007 06:52 PM
deetown
03-22-2007 12:44 PM
cdiddy
10-11-2006 11:09 PM
Quick Reply: 1996 7.3L tuner caused issues
