HPO Leak?
Old Nov 12, 2012 | 09:50 PM
holdtyte's Avatar
holdtyte
I wasn't sure if it was needed during the "no start". With KOEO I couldn't get an ICP pressure. The initial readings were at ECT of 190. The ECT during the no start dropped to 155.
Old Nov 12, 2012 | 09:52 PM
Fal-308-Win's Avatar
Fal-308-Win
You posted your oil as 0-40 w. Is that right?
Old Nov 12, 2012 | 09:56 PM
bismic's Avatar
bismic
If so - whose 0W-40 are you using?? What API ratings does it have?
Old Nov 12, 2012 | 09:57 PM
holdtyte's Avatar
holdtyte
Yes. I live in Southern Alberta but I work in Northern Canada. It is not uncommon to see -55 in Jan-Feb. I've been using it Nov-Feb for the last few years.
Old Nov 12, 2012 | 10:01 PM
holdtyte's Avatar
holdtyte
It is a CAT - arctic synthetic. I will get the ratings. I still have the 5 gallon pail in the shop. Will only take a few minutes
Old Nov 12, 2012 | 10:05 PM
Fal-308-Win
K , lets do it this way. Ipr % key on =14.84 , L idle =24 H idle= 40.60
icp key on = 0 L idle = 580-620 H idle =1400-1450
icv, key on=0.2. L idle = 1.0. H idle= 1._8
These are the readings you want!!!!!!
Old Nov 12, 2012 | 10:11 PM
holdtyte's Avatar
holdtyte
The oil I used is CAT DEO-ULS Cold weather 0W-40. API CJ-4, CJ-4 Plus. My Mistake... It isn't a synthetic oil.
Old Nov 12, 2012 | 10:14 PM
BLADE35's Avatar
BLADE35
You have a HPO Problem/Leak
Old Nov 12, 2012 | 10:18 PM
Fal-308-Win
If mark stays on board he can help you better than I.
good luck and good night
Old Nov 12, 2012 | 10:20 PM
holdtyte's Avatar
holdtyte
Thanks and good night
Old Nov 12, 2012 | 10:21 PM
holdtyte's Avatar
holdtyte
That makes me sad. I'm back at work tomorrow for 14 days. Now i know what I will be doing on my next set of days off. I'll search the forum while i'm gone for everything I will need to check into. While I'm at it I'll make sure i do the stand pipes, dummy plugs, stc fitting, hpop screen. Anything else that should be upgraded while I'm that far into the motor?
Old Nov 12, 2012 | 10:23 PM
holdtyte's Avatar
holdtyte
My ECT and EOT are good for now. Maybe do an EGR delete anyways?
Old Nov 12, 2012 | 10:39 PM
  #28
bismic's Avatar
bismic
I like the oil specs!
Sorry, but I agree w/ Benny on the HPO leak!!
When you are doing the work, pull the IPR valve and inspect the screen.
Personally I would install the BPD EGR cooler instead of deleting it. My opinion is that you need to tune it if you delete the EGR system (to properly account for the change in the engine programming).
Old Nov 12, 2012 | 10:43 PM
  #29
holdtyte's Avatar
holdtyte
Thanks for your help guys
Quackstacker
May 9, 2015 09:00 AM
Diesel 724
Sep 3, 2011 08:37 AM
M.Farragher
Oct 15, 2010 05:35 PM
ltl_jrw
Jan 2, 2010 06:29 PM
jimwilsonmasonry
Feb 11, 2008 07:35 AM
