1965 F250 4x4... I need 12 volt power that is ignition controlled ,for the electric choke on the carb. I know there is a post at the back of the switch itself, but I do not want to overload the switch. This must be a fused source. Any suggestions? I tried searching previous posts but didnt find this exact question. I did see something about avoiding the selenoid as a source... Thanks Roger
I use a ignition switched 12v source and the post on the switch is good one. You should use this source for power to switch on a 40 amp Bosch relay that then powers the choke. This way you are not adding a load to the switch and you get real 12v power for the choke. This deal works for any accessory that needs clean 12v power using our 48yo+ switches. Like the brighter brights deal for headlights or the 12v requirements of pertronix or an HEI. IMHO!
William ... I will be putting in a petronix system...will this need a seperate relay...Coming off the back post of the ingitionswitch are two wires...One is the cigarrette lighter...the other is maybe wipers?..I dont remember. I was afraid to add a third draw off the switch..what do you think??
A 12v switched source from anywhere turns on the relay (almost zero amperage necessary). One wire to ground from the relay. This circuit runs the relay. A solid 12v source (regulator, solenoid, alternator, battery) to the relay and out the other side to the work, in this case the choke or whatever you want to run with battery voltage. You can use larger wires for the work circuit ( I like 14 gage) and smaller to run the switched relay circuit, say 18 gage. The advantage is if something bad happens on the work circuit (like choke shorting out), the 48 year old ignition switch is not affected. Buy a relay and experiment using a test light and battery. After you figure it out lay out the circuit the way you want it. I have hung relays in the engine compartment, on the core support and under the dash. They are tough, reliable and cheap. I do use relays on Pertronix Ignitors, HEI and DUI systems. Really this stuff is easy once you experiment with it a bit. rwkinch, I'd use the starter solenoid Positive post if I were you. IMHO!
all great info...everybody!!.. Thanks so much for this education...I feel these precautions will help me protect this truck that I painstakingly am trying to preserve!!! Roger..
