Sponsored by: Real Truck
no low 4x4 esof
Old Nov 11, 2012 | 08:21 PM
jccapri's Avatar
jccapri
no low 4x4 esof
4x4 works in 4 high put in 4 low and you hear some clicking and then it goes to 2 wheel drive and will not go in 4 low or high at that time kill the truck and restart it and it will go in 4 high if you try 4 low again you have to kill it and restrat to use 4 high 2001 f350 cc 7.3 4x4 esof auto
Old Nov 11, 2012 | 09:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
Tell us exactly what you do when you shift into 4L.
Old Nov 11, 2012 | 09:18 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Are you in neutral with your foot on the brake? If not, that is your reason
Old Nov 11, 2012 | 09:33 PM
jccapri's Avatar
jccapri
in neutral foot on brake i go to 4 h when light is on i go to 4 l i have had 3 trucks with the esof 2 were gas 04 and03
Old Nov 11, 2012 | 09:35 PM
jccapri's Avatar
jccapri
i do have the vacuum part unhooked at the fender i lock hubs
Old Nov 11, 2012 | 10:12 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Have you actually driven it in 4x4H to verify it is working? If it is, I will send you the testing/troubleshooting steps to follow for 4x4L.
Old Nov 11, 2012 | 10:19 PM
jccapri's Avatar
jccapri
yes i used it to pull logs last weekend 4 h would spin all 4 tires 4l only rear tires
Old Nov 11, 2012 | 10:22 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Ok. PM me your email address, and I will get you the troubleshooting procedures to pinpoint the cause.
Old Nov 11, 2012 | 10:56 PM
garryk6's Avatar
garryk6
I have the exact same problem on my 2002 F350 5.4 ZF-6. I am planning on ditching the entire ESOf. Currently have all the manual shift pieces, just waiting for a good day to pull the motor and do the welding and cutting on the motor to accept the manual linkage. But since my Ex still has all the ESOf stuff I'd like the troubleshooting info. I'll shoot you a pm.
Garry in kodiak, ak.
RIDE RED
Apr 18, 2018 10:37 PM
f350v10415
Aug 29, 2013 07:47 AM
slowcoupe
Mar 23, 2008 10:25 PM
WWBeast
Sep 23, 2007 08:58 AM
3Mike6
2004 - 2008 F150
Oct 19, 2004 10:18 AM
