4X4 Low indicator?
Old Oct 16, 2004 | 11:13 AM
3Mike6's Avatar
3Mike6
4X4 Low indicator?
Quick question regarding my '04 4x4 SCREW.
Should the 4x4 low indicatior light something up on the dash?
4x4 High does, but when I flip it over to 4x4 low, nothing is lit???
Thanks
Old Oct 16, 2004 | 11:29 AM
YOMAN's Avatar
YOMAN
Did you follow the instrcution?
Did you try this, put it in netural/brake it, shift to 4Low then you ll see the light pop up
Hope that helps!
YOMAN!
Old Oct 16, 2004 | 12:09 PM
Dr No's Avatar
Dr No
YOMAN is correct.
It won't go into 4x4 low while moving.
You may also have trouble getting it out of 4x4 low whihe moving.
Mike
Old Oct 16, 2004 | 02:26 PM
3Mike6's Avatar
3Mike6
I didn't try it from neutral, just from Park...i/e, engine running, flipped it to 4x4low...I'll try the foot on the brake thing when she gets home
Old Oct 18, 2004 | 09:34 PM
DWEELER's Avatar
DWEELER
3Mike6,
I'm sure when you try YOMAN's procedure, your 4x4 low indicator light will come on. But in case it doesn't, check to see if it comes on when your ignition switch is in the ON position. All the indicator lights are on then. If not, the bulb or LED or whatever they're using these days may be bad.
Old Oct 19, 2004 | 10:18 AM
jdmclemore's Avatar
jdmclemore
Has to be in Neutral, not Park. That's probably it.
