Brakes????
Old Nov 11, 2012 | 06:39 PM
ROKRAWL's Avatar
ROKRAWL
Brakes????
I have a brake problem. When I come to a stop at a light or stop sign there is pressure at the pedal, however it gradually loses pressure and moves all the way to the floor. The brake warning light will come on, I'll pump the brakes and the light will go off and i will have pressure until the next stop. Last week while driving this happened and the light would not come off and the brakes would not regain pressure. I bled the system and now I'm back to only having the pressure problem when I'm at a stop. What should I do? Not sure what needs replaced, if anything. Thanks.
Brett
Old Nov 11, 2012 | 06:56 PM
VocaTexas's Avatar
VocaTexas
Assuming you have checked and not found any leaks, it sounds like your master cylinder is out.
Old Nov 12, 2012 | 06:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pressure on brake pedal, it sinks to the floor. It's the master cylinder and if you have power brakes, it's leaking into the booster.
Old Nov 13, 2012 | 07:50 PM
ROKRAWL's Avatar
ROKRAWL
Is it advisable to replace both booster and master cylinder or just the master cylinder?
Old Nov 14, 2012 | 09:07 AM
4x4 Bart's Avatar
4x4 Bart
Try just replacing the Master. Be sure to bench-bleed the new master.
Old Nov 14, 2012 | 07:57 PM
ROKRAWL's Avatar
ROKRAWL
Done. Works perfect. Thanks alot.
Grantmh6.4
Nov 4, 2018 09:38 PM
91Bronc300
Mar 11, 2010 01:37 PM
CollinsCD
Apr 17, 2006 11:44 AM
Haaser
Jul 1, 2005 10:07 PM
barebackjake
Apr 16, 2005 10:39 AM
