Heater core
Old Dec 28, 2012 | 11:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Heater fan controls are a frequent topic, here's my experience:
https://www.ford-trucks.com/forums/1...n-control.html
Old Mar 24, 2014 | 10:30 PM
flclassics's Avatar
flclassics
1949 F1 Heater core wanted
We are looking for a heater core for this same heater box. Someone, I am not pointing the finger, took it out and tossed it away thinking that he could get a new one. Any assistance will help him out.
Originally Posted by KJLYPW
3 door heater in my 48 F-68, Canadian built truck. Heater core leaking a bit, so pulled it apart, took off one of the tanks, sure enough full of crud. Will try cleaning cores out, but pretty sure by the time thats done all the buried corrosion under the crud, it will leak a lot more.
Any ideas if anyone makes an aftermarket replacement core, or has a good used core. Alternatively, once I get it cleaned out anyone know of a good "mechanic in a can" product to try and plug up the leaks- heater core only, wont put it in the engine.
Old Mar 25, 2014 | 11:10 AM
fifty-two_f1's Avatar
fifty-two_f1
Those are tough to find. You can use a mid to late 40s international heater and swap tubes. Its not quite as thick, but can be made to work.
MIRONWORKER
1997 - 2003 F150
Dec 24, 2017 10:23 AM
vanceboroguy
Nov 24, 2014 09:09 AM
dohc_chump
27
Sep 28, 2010 03:04 PM
56restore
Jun 30, 2004 07:11 AM
GreatNorthWoods
Feb 22, 2004 07:10 AM
