radio test
Old Nov 10, 2012 | 07:10 PM
benbuilder's Avatar
benbuilder
radio test
I just picked up a 75 ish ford radio. i wanted to bench test it before I installed it. I ran a positive wire to the radios green square box, and I ran a negative from the battery to the bolt in the rea of the radio. I got nothing to light up. I then tested the bulb for the night light and the bulb works fine. So I have determined that the unit does not work or the ground is not sufficient. What are your thoughts? Shoud I mount the radio to see if it works? Or shoud I screw the ground into the rear of the unit? Another question is, ihe green matching couping from the wire harness hs two leads in it, shoud they both have constant power?
Old Nov 10, 2012 | 07:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The green plug lead that has the fuse is power (+) the other wire (blue w/ red stripe) is power for the backlight. The radio grounds through the chassis.
Is the radio AM or AM/FM Stereo?
Old Nov 10, 2012 | 07:27 PM
benbuilder's Avatar
benbuilder
radio
it is am fm. Do you think a wire from the batt on an alligator clip iss not sufficient ground and I need to install it?
Old Nov 10, 2012 | 07:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No that should be okay. Have you got the speakers connected?
Old Nov 10, 2012 | 07:30 PM
benbuilder's Avatar
benbuilder
radio
Also, the fuse seems to be enclossed pretty good, is this type abe to change a fuse? if so how?
Old Nov 10, 2012 | 07:31 PM
benbuilder's Avatar
benbuilder
radio
No I did not instal speaker wires, I was looking for llights first.
Old Nov 10, 2012 | 07:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Does your wiring look like this? The fuse holder is the white cylindrical piece.The fuse is easy to change, just push the two housing halfs together and twist then pull the holder apart.
Old Nov 10, 2012 | 07:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Double post .
Old Nov 10, 2012 | 07:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, to get the light to light, you'll need to run power to the blue/red stripe wire. The light's operation doesn't have anything to do with the radio's on/off switch.
I've also heard it's not good to power up the radio without having the speakers connected.
Old Nov 10, 2012 | 09:37 PM
VocaTexas's Avatar
VocaTexas
I've sent two radios to a shop in San Antonio to be fixed. The guy does a great job. He doesn't restore them, but he cleans them very well and everything works like new when you get it back. Prices are very reasonable, too. He specializes in Delco radios, but does Philco as well.
Delco radio repair, car stereo & auto radio repair and precision radio repairs.
Old Nov 11, 2012 | 04:14 AM
RunninD's Avatar
RunninD
While it's there you might see if he'll wire in an aux input jack. I had it done with mine, and it allows me to run my I-pod through it. Basically when the I-pod is connected it becomes the antenna source. Cost in parts was under $5. I set mine on a 12" extension so I could just drill a small hole in the dash by the ashtray, which I'm turning into a covert charging / storage station for my phone and I-pod. won't cost much more, but makes life really nice on a cloudy day out here in the hinterlands!
Old Nov 11, 2012 | 04:31 AM
benbuilder's Avatar
benbuilder
radio
Runnin D thanks for that info. Mike, I am familiar whit the white fuse you have shown. I do not have that, I have a black tube like piece that looks similar to yours then the wire goes straight into the plug. No cut wires. I will give it one more try today, then assume that it does not work. Thanks.
Old Nov 11, 2012 | 05:17 AM
benbuilder's Avatar
benbuilder
Mike/RuinD,
What is the name of the radio guy? Thanks
Old Nov 11, 2012 | 05:57 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The black tube like piece I believe is an inline filter.
Don't worry about getting the light working, that won't tell you if the radio does or doesn't work. To see if the radio works you'll need to hook up the power, an antenna and a couple of speakers.
Old Nov 11, 2012 | 05:58 AM
RunninD's Avatar
RunninD
The guy I used is in Scottsbluff Nebraska. His name is Gene Cochran, and he works out of his house. He's a crusty old codger, but does some tremendous work. While he had the radio apart, he updated some of the internals and cleaned the heck out of everything. My total bill was $25! His number is 308 632-2520 (I checked with him at the time I collected my stereo, and he was OK with giving his number out) He also lined me out on the manner in which the old radios were wired (mine at least). The speakers are in series meaning positive from radio to positive on speaker #1, negative from that speaker goes to positive on speaker #2. Negative from Speaker #2 goes to Negative on stereo. Now the stock stereo rocks as loud as the little 51/2 speakers can handle!!!
One of the best mods I've ever done (had done)
