Help with diagnostic troble codes!
Old May 21, 2003 | 05:15 PM
pikiluvi's Avatar
pikiluvi
Do anybody had have the code
# 332 ( Insufficient EGR flow? IF so! how can I fit it?
I also have codes:
#634= MLP sensor voltage out of self-test range.
#653= trnsmission control switch did not change states during KEOR self- test
# 654= trnsmission range sensor not indicating "PARK" during KOEO self- test
#452= insufficient input from VSS(what's the VSS?)
Can somebody help me with this codes and tell me; where I need work. Thank's
Old May 21, 2003 | 10:52 PM
steve83's Avatar
steve83
Read this. 653 means you didn't shift the lever when the computer prompted you to, or (considering 654 & 634) the MLPS is bad. VSS (Vehicle Speed Sensor) is the one on the top of the rear diff. 332 is usually a vacuum leak at the reservoir on the R wheelwell.
What vehicle/engine are you working on?
Old May 22, 2003 | 08:53 AM
pikiluvi's Avatar
pikiluvi
Thank's Steve.
Old May 22, 2003 | 12:49 PM
steve83's Avatar
steve83
Originally posted by pikiluvi
How do I change the" MLPS" on a E4OD ..
It this something that I can do myself ?
It's easy if you have a couple of wrenches. The Haynes manual would tell you exactly how, but basically, chock the wheels, put it in Neutral, unbolt it, disconnect the wires, plug in the new one, & bolt it back on so the marks are aligned.
Old May 22, 2003 | 03:35 PM
pikiluvi's Avatar
pikiluvi
Thank's againg Steve
Old May 22, 2003 | 09:58 PM
steve83's Avatar
steve83
Still not going to say what kind of truck you have?
Old May 24, 2003 | 04:01 PM
pikiluvi's Avatar
pikiluvi
Sorry; I have been working and have not login in a while; I have a 1994 F-150. auto whith the 4.9 on it.
Old Jul 21, 2004 | 07:11 PM
EBaker's Avatar
EBaker
I have a 1998 Ranger with a 3.0 V6 I am showing a DTC of P1400 (Differential Feedback EGR Circuit Low Input). Does anyone know what that means????
Old Jul 21, 2004 | 07:49 PM
Gary B's Avatar
Gary B
check for a broken upstream DPFE sensor hose(one of 2 hoses from exaust manifold to sensor) if it is ok the sensor is probally bad
Old Aug 11, 2004 | 06:07 PM
CLUELESSWINNER's Avatar
CLUELESSWINNER
Exclamation
I also have 94 F150 with a 4.9 engine. I have pretty much the same problem. We removed the EEGR valve (located north/center of engine capartment when facing engine) and cleaned it and reattached it. There is a great big difference, but not perect. I thought the EGR sensor (connected to EEGR valve) or the EGR solenoid, but a manchanic told a friend it was the EEGR valve. So I'm going to buy a new one (runs about $85.) Keep your finger cross. I'll keep you posted.
flare-f150
1997 - 2003 F150
Jul 20, 2015 06:42 PM
Tomget
1983 - 2012 Ranger & B-Series
32
Apr 11, 2015 08:41 AM
kriswears
Aug 7, 2004 09:53 AM
croman2
Jul 19, 2004 06:44 AM
Leadsled Coupe
May 6, 2004 05:20 AM
