I have a problem with my truck.. It's a 1991 F350 7.3 4x4..
When I drive around with the light switch off.. it works just fine.. as a dream.. But when I turn the lights on, pull the switch to the first click (or the 2nd) it's like the gear jumps out.. and does not really jump in again until I push the throttle.. This is noticable when I'm driving 50-60mph
If anyone have had this problem I would greatly appreciate you sharing your story
Do I dare to drive around or should I be afraid of getting damage to the gearbox?
Check/clean the grounds on the radiator support (driver side) then for giggles and grins do the same for the grounds near the starter relay/battery on the passenger side.
I have seen poor grounds cause transmission and driveability problems when the headlights were on more than once.
That's interesting.. that thought never occurred to me.. should it not be hard to start if the ground was bad?
No, these grounds (G100 and G101) are for the PCM, transmission, lights, and other chassis grounds. A bad ground leading to the engine (G106) would make the truck hard to start.
The Transmission Electronic Control Assembly (TECA) is tied to ground G100 on a diesel truck along with the headlamps, marker lamps, etc.
A bad ground for a tail/brake light could be letting power back feed to the brake light circuit through the bulb from the tail light circuit and cause the torque converter to unlock..
All it takes is a tap of the brake pedal enough to light the brake lights to drop the lock-up converter..
Are you talking about a ground from the battery to engine ?
G106 is the ground leading from the negative side of the battery to the engine block. It may also have a tie-in to the frame along the way. Diesels have two batteries so the path may be slightly different.
