Shift lever modification
Old Nov 9, 2012 | 01:55 PM
52' fordnut's Avatar
52' fordnut
Hello,
I'm rebuilding a 52' Ford pickup and I am using a M5R2 5 speed transmission behind my 302. I am wanting to change the awkward modern slant gear shift lever for something a little more vintage. Has anyone ever done this before? I am wanting to just use some thick round stock and paint it black. Any ideas, suggestions, concerns?
Thanks as always!
Jon Preston
Old Nov 9, 2012 | 02:37 PM
Mervy49's Avatar
Mervy49
Can your lever be heated up and bent to your desired shape?
Old Nov 9, 2012 | 02:42 PM
52' fordnut
I would say it could be, but I'm sort of wanting to do away with the shift lever and get one that's not as modern looking. I want it to Kind of look like the original when people look inside of the truck.
Thanks again,
Jon Preston
Old Nov 9, 2012 | 03:06 PM
The Horvaths's Avatar
The Horvaths
Time to go see the local blacksmith!
Actually, I forge a little myself. You could check to see if there's a blacksmiths' club in your area, or, just heat and bend and weld away to your heart's desire.
Old Nov 9, 2012 | 05:08 PM
rhopper's Avatar
rhopper
Sounds like heating and bending is the solution. I used electrical conduit for my shifter. I don't have a tubing bender, so I heated an inch or so at a time and bent it just alittle. For the tapered section that the **** sits on, I used part of the s10 shift lever I had, cut and welded to the conduit.
Old Nov 9, 2012 | 05:33 PM
John Peterson's Avatar
John Peterson
Check out Lokar Performance Products @ Lokar Performance Products: 1-877-469-7440
rexblue
Apr 19, 2015 08:29 AM
midnight_mp
Jan 20, 2008 05:30 AM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
