Vwery slow coolant loss, where to?
Pushing 55,000 miles and decided to test my cap and coolant system...
Borrowed a tester from O'reilly. Cap goes to 16 then slowly leaks down to 7 over a 60 second time frame.
Threaded adapter won't thread onto degas bottle but the male and female adapters thread together fine so I'm not quite sure what's going on there.
It's the "Threaded cap" adapter kit.
The cap fits the male adapter and holds some pressure. The female adapter doesn't thread onto the degas bottle. It starts, gets about 1 full turn then tightens up but the seal isn't complete. Was worried about cross threading or damaging the degas bottle.
The male and female adapters in the kit fit together just fine.
That's what I got.
I was actually outside trying as you posted this... I put a good amount of force to it and barely got it tight enough to allow the rubber washer to touch the lip of the degas bottle. Still wouldn't hold more than 5-6 psi though. Might see about getting an extra washer or two to take up the space. Not sure if multiple washers would hold the pressure though.
jackstraw
07-08-2019 08:01 AM
StanleyZ
6.4L Power Stroke Diesel
51
10-26-2014 09:30 PM
