Bearing tolerances
Old Nov 8, 2012 | 12:11 AM
crazy96863's Avatar
crazy96863
Bearing tolerances
Found some end play in a few connecting rods; pulled the caps and most had worn bearings although only a few to the point they had play... Trying to figure out what the tolerance for new bearings should be.
Also, this will sound a little dumb but is there any allowance for wear around the crank? What I am asking about is does the crank need to be perfectly round or is it ok to be a few thousandths out?
Thanks!
Old Nov 8, 2012 | 06:48 AM
baddad457's Avatar
baddad457
I've "re-bearinged" many cranks without turning them. If the journals do not have any visable signs of wear, they're usually good to go with new bearings. Most Ford cranks are incredibly tough. The 351W I put back together in my 95 was done with a used crank of unknown history, sat in a shed for a couple years, I brought it home, cleaned the journals up with emory cloth, bought new .001 undersized bearings and used it like that. With a std volume oil pump, the pressure at idle is 30-40 psi hot.
Old Nov 8, 2012 | 08:41 AM
crazy96863's Avatar
crazy96863
I think the oil pump this thing has is another issue; it might explain some of the excessive wear it has in a few areas. I was going to get a standard pressure, high volume pump from summit for $35 or so just for safe measure.
Thats reassuring about the crank journals... Would you even check the tolerances on new bearings? There are no signs of wear. The top bearing on most rods were all copper/brass looking but there is no scoring or anything.
Old Nov 8, 2012 | 06:46 PM
baddad457's Avatar
baddad457
It's not a bad idea to do so, but I've done several in the past few years without doing so, and so far, nothing bad has become of it. All these motors were roller 302's with over 100K miles on em. All had good oil pressure afterwards and none exibited any unusual noises in operation. It's your call, but like I said, if the journals aren't scratched or scored, they should be OK.
Old Nov 8, 2012 | 06:50 PM
crazy96863's Avatar
crazy96863
Cool cause thats what I wanted to do. This is that replacement motor for the boat; I just want to get it done so it wont rip itself apart but nothing super expensive; basically a reliable j/y build. A buddy was trying to get me to regrind 'just cause' the motors out already but I dont want to put that kind of money into it right now. Thanks for all the feedback.
Old Nov 9, 2012 | 09:47 AM
crazy96863's Avatar
crazy96863
Is there some sort of bearing break grease I should apply here?
Old Nov 10, 2012 | 08:05 AM
baddad457's Avatar
baddad457
Do not use grease. I use STP oil treatment as assembly lube.
Old Nov 10, 2012 | 08:59 AM
crazy96863's Avatar
crazy96863
Thats what I wa referring to... Didnt know what it was called but seem straight forward. Picked up a big @ss tube of it for $7 @ Oreillys.
1ole4d
Jan 1, 2009 05:29 PM
straightsix4x4
Jul 22, 2008 09:47 AM
141bpm
May 8, 2005 07:45 PM
The Shadow
13
Oct 26, 2004 12:10 PM
fishin1976
Jul 10, 2003 12:14 PM
