It's Here It's Here! My New Project!
Old 11-07-2012, 01:10 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
Arrived on the tow truck before lunch. The previous owner bought it and never even started on it so he couldn't tell me much about previous work.
1977 F250 4x4
460 (not sure where it came from or what is inside but it runs like a champ and sucks gas like one too)
C6 (not sure if it even works)
First Tasks:
1. Do something about my work area. Need to build a work bench.
2. I have a lot of tools and just went and got a new compressor but I budgeted $1000 for tools so need to get a sprayer and some nick nacks.
3. Figure out what is wrong with the drivetrain. Doesn't kick into gear.
4. Rear main seal is leaking so I need to fix that.
5. Find a tailgate
6. Fix the hood latches
7. Put the exhaust back where it belongs so I don't die of carbon monoxide poisoning... and add new flowmaster in the process.
8. Sand, rusto, and spray in bed liner for the bed.
9. Gut interior and install new stuff.
10. body work & paint.
11. Put on 37" Military Tires
After this initial resto I'd like to rip it down to the frame and paint everything up and add new suspension but I've only got $3000 left for this project so that might have to wait.
Old 11-07-2012, 02:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
NICE!! Keep us updated on your progress (or lack of).
Old 11-07-2012, 03:44 PM
gpence's Avatar
gpence
gpence is offline
Your seat looks as bad as mine. Lol
Old 11-07-2012, 03:52 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
It has seen better days that's for sure. Smells too.... Gonna replace it with a newer console seat if I can find one that fits.
Old 11-08-2012, 07:54 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
So I fixed issue 1. It was the hub lock and a trans leak. Now the DMV is saying I'm 2 years short of collectors plates so I have to get Colorado emissions... Gonna have to do some exhaust work now and find a pair of cats...
Old 11-08-2012, 09:11 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Looks like a good truck to start with. Cool color too.
Old 11-08-2012, 09:34 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
Tonight's harbor freight shopping list:
1-1/2 gallon Texture Paint Spray Gun
Central Pneumatic
Item #66103
$24.99
20 oz. High Volume Low Pressure Gravity Feed Spray Gun
Central Pneumatic Professional
Item #66222
$34.99
Oil/Water Separator
Central Pneumatic
Item #68246
$5.99
Sander/Polisher 7" Variable Speed
Drill Master
Item #69474
$39.99
5 Piece 7" Polishing/Sanding Set
Chicago Electric Power Tools
Item #94323
Old 11-09-2012, 11:43 AM
JunkyardFord's Avatar
JunkyardFord
JunkyardFord is offline
Looks like an excellent truck to start on. Please keep us updated and more pictures coming. Good luck getting it on the road.
Old 11-09-2012, 11:56 AM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
Fixed this wonderful piece of ingenuity this morning. Looks like someone patched a transmission cooling line with a hose that was way too big. I replaced it with fuel line hose and 4 fuel clamps until I can track down a new line. No more transmission leak. Just waiting on my rear main seal to get in and valve cover gaskets and that should take care of the last of the leaks. Please don't ever use oil stop leak! fix the problem!
Old 11-09-2012, 12:35 PM
gpence's Avatar
gpence
gpence is offline
I had some bucket seats out a 90's bronco in mine for a while.
Old 11-09-2012, 12:40 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
did the bolts match up or did you have to drill new ones?
Old 11-12-2012, 06:13 PM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
Found a tailgate on CL for $25. I lucked out that it fits and is the same color also. needs some dent repair but can't beat the price. Other than that been building a workbench over the weekend.
Old 11-17-2012, 09:50 AM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
Had the flu this week so didn't get a ton done. I started grinding on the tailgate I got. it may end up being a test project for my new welder. I did however finish my new work bench so my shop is almost ready for the restoration. Oh and I found a cool radio that I ordered.
1973-1979 Ford Truck Radio, USA-1 | Classic Car Radio & Speakers
Old 11-17-2012, 09:59 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
As far as the trans cooler line goes, just go to the auto parts store and get a 6' length of 5/16" steel line. Bend it how you need it and call it a day.
Don't burn through all your money on neat little nic-naks. Take the time to go through the truck and make a list of stuff you HAVE to have. There's nothing worse than having a neat radio but can't get it inspected because you don't have the money left over for cats.
Old 11-17-2012, 10:22 AM
Jimmyrig's Avatar
Jimmyrig
Jimmyrig is offline
The truck didn't come stock with cats so I found out I don't need them. I took it to get emissions the other day and it barely failed Co2 so it really just needs a carb adjustment because its running a little rich. Mechanically other than that the thing runs perfect. I spent several hours this week combing the truck for issues. I probably spent 2 hours under it just staring at the bottom of the truck. I had $700 budgeted for emissions but due to this I splurged a little on the radio
Things I did find: Power steering pump leaks. Shoulder strap drivers seatbelt doesn't work. Blinkers don't work. Seals on doors leak. Someone put a brand new HUGE fuel pump right under my butt and its annoyingly loud. Any ideas on moving this would be helpful.
Quick Reply: It's Here It's Here! My New Project!
