I am having issues with my locks, door registering open, and automatic headlights.
I cannot get my doors to lock with anything (Key Fob, Keyless Entry, or the button on the door panels). My automatic headlight feature will not work, and when my doors are open it does not register that they are.
Generally for the doors, the interior light switch is built into the latches and they like to get stuck. Most people spray a liberal amount of WD-40 up into the latch and then open and close the door a few time to work it in. This usually frees up the stuck switch. In your case it sound like you're saying the problem exists for all doors. That would make me lean towards a blown fuse.
It is for all the doors, and I have checked all the fuses and non of them are blown, I also checked all the relays.
