zf conversion
Old Nov 7, 2012 | 01:35 AM
bigbrown1985's Avatar
bigbrown1985
zf conversion
alright so here's the deal i haven't done much research on it just wanted to see what you guys thought. i have a 95' powerstroke with the e4od and i want to put a zf5 or 6 in it what all do i have to do?
Old Nov 7, 2012 | 01:47 AM
75Three90's Avatar
75Three90
im not sure if the drive shaft it diffrent as far as lengeth but i do know a computer swap and wiring need to be changed as well as the starter, fly wheel, brake pedal assembly, mount a slave cyclinder clutch line cut a hole in the floor board ect ect its a P.I.T.A but its sooooooooooo worth it if you willing to do it if you do things right and bust your **** then in 2 to 3 days youll be done
Old Nov 7, 2012 | 02:24 AM
stainlessstroker95's Avatar
stainlessstroker95
There is two good write ups on here that i know of. I would post the links but im on my phone. Buckhammer, Tyler and Bill (rebilld) have done the swap. You dont have to change the starter. I do know that.
Old Nov 7, 2012 | 02:29 AM
75Three90's Avatar
75Three90
i thought the starter was diff between man and auto i know it is on older trucks hmm thats convient
Old Nov 7, 2012 | 02:36 AM
stainlessstroker95
It is the same. You dont even have to remove it to pull the trans.
Old Nov 7, 2012 | 02:40 AM
75Three90's Avatar
75Three90
i was always told the starter was diffrent only by an 1/8 or so damn ive been wasting money all these years
Old Nov 7, 2012 | 02:41 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The starter between manual and auto on these 7.3s can be interchanged. So, no changing required.. On gassers though, it is required to change the starter on most of them.
Old Nov 7, 2012 | 02:48 PM
bigbrown1985
yah its the powerstroke but what about cross members and stuff like that?
Old Nov 7, 2012 | 03:19 PM
ReBilld's Avatar
ReBilld
These are things you need from a manual truck to convert yours
Pedal assembly
Clutch master and slave cylinder
Clutch safety switch
PCM, or get your PCM flashed to manual
Steering column cover and key release swith
Center hump with shifter hole
Manual trans and t-case wiring harness
T-case shifter linkage bar
Cross member
Front and rear drive shafts, or have your rear drive shaft lengthened and the front one shortened
Flywheel, clutch and pressure plate
ZF5 transmission
The ZF trans is about 5" shorter than the E4OD. You need drive shafts from a manual truck with the same cab configuration and wheel base, or have your drive shafts modified.
Old Nov 7, 2012 | 03:48 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The best advice I can give is go find a donor truck that has EVERYTHING on it.
If you go buy a trans, pedals, and master/slave assembly, you're maybe 1/3 the way there.
There is a ton of little things that you will need.
Having a complete donor truck is the only way to go.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 7, 2012 | 03:56 PM
ReBilld's Avatar
ReBilld
X2^^^^^^^That's what we did. I don't recommend trying to find individual parts.
Old Nov 7, 2012 | 05:29 PM
redman84's Avatar
redman84
Pedal assembly
PCM, or get your PCM flashed to manual ****
Steering column cover and key release swith ****
Cross member
ZF5 transmission
You can have a functional manual truck without the the things with the **** beside it but the auto PCM has caused a romp at startup for several people. The column cover and key release is nice and makes it look a little more complete.
Also, for your 95 you will need a rear driveshaft from a truck the same cab configuration AND same t case. I believe the front section is different lengths between a 1356 and 4407 t case. The rear section is the same length from 94-97. Most of the 96s and 97s have 4407s but several guys have claimed 1356s in 96 trucks.
^^^x3^^^ I started gathering parts and took them all back to look for a donor. Thank goodness I did. It made it way easy on top of having all the extra parts. You buy a donor and the vultures will start circling though .
Another option is find someone who has a manual and wants an auto.
Old Nov 7, 2012 | 05:30 PM
redman84's Avatar
redman84
Oh yeah, search for tybragg's thread. It has the most info in one spot on this topic probably anywhere.
Old Nov 7, 2012 | 06:33 PM
ReBilld's Avatar
ReBilld
Good info Jacob. I forgot about the different t-cases. We ran into that on Tyler's. He had a 4407 in his '97 and the donor was a '94 with a 1356. We just put the 1356 in his truck. Now were gonna take it all back out and put it in the cc he just bought, and put his ec back to an auto! LOL!!
Old Nov 8, 2012 | 12:11 PM
TyBragg's Avatar
TyBragg
X4 on the donor truck!
Here's the link to my thread:
https://www.ford-trucks.com/forums/1...n-process.html
It's not really all that bad...if you have the donor truck. I think we had everything ripped off the donor in a day (except for a few little things we forgot at first), then it took us about a week of evenings to put the zf5 in and get everything working (backup lights require wiring harness modification, in order to key start requires wiring mods, cruise control required wiring mods...but they are not too bad. All the info is in my thread, and I made some wiring diagrams - they're in there too).
Like Bill said, we're getting ready to "undo" the swap in my ECLB and convert my CC I just got to a 5 speed, turning the ECLB back into an auto so I can sell it. I'll definitely be referencing what we did before...cause I can't remember exactly on some of the stuff! Man, I'm glad I did that write up now! If you get into it and have concerns, just let us know.
