Rebuilt 300 Help!
Old Nov 9, 2012 | 09:32 AM
AbandonedBronco's Avatar
AbandonedBronco
It's definitely possible.
As said, auto parts stores will check those for free.
They're held on with 3 screws that you access from the wheel well. A 7/16" if I remember right.
Just pop it off, take it down, and have it tested. Be sure they run it 3 or 4 times since some only fail after they're warmed up.
Old Nov 10, 2012 | 12:48 PM
6978sghfbjklgdfsjhkl's Avatar
another thing to consider
I wanted to ask whether or not you have checked the compression on all cylinders and compare which may be low?
Also, have you located which cylinder might be the culprit? (removing a plug-wire and comparing engine rpms as you check each cylinder?
Old Dec 14, 2012 | 09:50 AM
jack orchard's Avatar
jack orchard
What did you find wrong? Plug wire?...jack
1968 F250camper
28
Jul 17, 2018 09:59 AM
lee
Aug 3, 2015 11:30 AM
smithwoods
Jun 11, 2009 12:03 AM
mike460
Feb 6, 2002 05:55 PM
craig429
Jan 6, 2002 03:44 AM
