Autolite 4100 question
Old Dec 6, 2012 | 11:50 AM
F-250 restorer's Avatar
F-250 restorer
Anyone know if the screw in filter in the front of the carb reduces fuel psi coming into the carb?
I can't use the filter b/c it hits my v.cover. Now with two different 4100's I'm having probs with fuel flowing past the needle/seats. Needles are vitron. I've tried three sets. I've adjusted floats from top to bottom, with no effect.
Measured psi into carb at 4 or 4.5, can't remember which. That shouldn't be a problem.
Old Dec 6, 2012 | 01:09 PM
tiap's Avatar
tiap
Imagine the strainer on your kitchen faucet becoming clogged.
You end up with less flow and pressure.
Old Dec 6, 2012 | 04:11 PM
6978sghfbjklgdfsjhkl's Avatar
another prospective.
I hope I'm not embarrassing my self but, Has anyone asked..what kind of float ur using? I use brass myself. I can't imagine a good tight float NOT sealing of 4-5# of fuel pressure..I can remember when we would use up to 8psI or so in carbs back in the day and not have problems..(when everything ran a carb, and most all floats were brass...) just another look at the problem
also i don't think you want to adjust the float too low..there won't be enuf fuel in the bowl to effectively "float" the float which gives the pressure to close the needle. When that float is "immersed"..it can exert a lot of pressure...
Old Dec 6, 2012 | 07:37 PM
F-250 restorer
Thanks for the responses. I guess my point is that no one knows the psi coming out the oem filter going into the carb. After experiencing spurting past the needles/flooding on two 4100's, regardless of where I set the float level, with both brass floats and the neoprene ones, with 4 different sets of needles/s, I can only reason that the oem filter is not there only to filter, but to cut psi to a manageable level as well.
It took one of the inline crowd, mounting it 90* to the engine, to figure that out. (Hopefully that is the problem.)
Wow, the forum blocked the link to my auto blog in my sig! Interesting.
Old Dec 6, 2012 | 08:05 PM
tiap's Avatar
tiap
No one can tell you the pressure unless you measure it and those little inline fuel guages are notoriously inaccurate, at best giving a rough average pressure, not seeing the fast spike pressures which could easily pop the valve.
Any restriction in the feed, whether it be 90s, filters, bends, fittings or just long runs will ALWAYS reduce the pressure, just like the water faucet.
As I mentioned in another thread, install a positive working regulator with a return to tank, it's flow that you need, not pressure. The fuel pump is a very, very crude regulator of sorts, being a variable displacement pump. I've set carbs up with as little as 2psi and they run great floored all the way to redline. You don't need more fuel than that.
Old Dec 7, 2012 | 11:22 AM
rustywheel68's Avatar
rustywheel68
this sounds strange.
i'm running a 4100 on my Galaxie, but i can't remember off the top of my head if i have a screw-in filter on it or not. i'll check it this weekend.
but- on my I6, i'm running the stock fuel pump/paper filter straight into a 2100- no screw-in filter. its doing fine.
Old Dec 11, 2012 | 10:55 PM
F-250 restorer
BTW, I found the brass bushings for the 4100 throttle shaft. I guess I can't get away from Mike's Carburetors. He is the only guy who has them.
Old Dec 14, 2012 | 09:54 AM
rustywheel68
Finally remembered to check the Galaxie last night- i do have a screw-in filter there.
No screw-in filter on the 300 with the 2100.
Old Dec 14, 2012 | 11:34 AM
F-250 restorer
Thanks for checking. I've decided to either go with a $28 Holley fuel psi regulator ( 1 to 4 psi) from Summit, or just run one of the filters inline with fittings. (I'm sure if I buy the fittings from Napa the cost will be close to $20.)
I'm itching to get back to my 4100 'spreadbore' experiment, and/or my 1.08 (480 cfm) 4100.
Old Dec 14, 2012 | 02:08 PM
Harte3's Avatar
Harte3
Carbed Ford Message Board • Index page
Don't know if you are familiar with that site but it may have some info on your Autolite carb.
Son's79f-150
Mar 15, 2014 07:33 PM
dorf dude
Feb 17, 2013 08:04 AM
F-250 restorer
Dec 8, 2012 05:27 PM
19Ford69
Mar 12, 2004 06:32 PM
cigarxtc
Apr 11, 2003 11:38 AM
