Sliding Window Leak
Old Nov 6, 2012 | 04:41 PM
wag53's Avatar
wag53
Sliding Window Leak
Hello, I have a '93 ext cab that I just put a sliding window in from a '97 F250. Used a new gasket from LMC. Went in easily but have a small problem, it leaks. Not at the seal, but between the slider and the fixed glass. There appears to be a drain hole on both sides in the slider channel, but it goes nowhere. The question is, can I drill a hole in the gasket on the outside to the drain holes and put a small tube in it to cure the problem of water running inside the cab. Oh yes, I was using a hose not rain so it might be that I squirted the water in and there is no problem.
Old Nov 6, 2012 | 05:21 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Dumb question but did you install it correctly, not inside out? If you did, fish a wire through the drain hole to see where it goes outside under the gasket before you drill or cut anything. The gasket may be a little wider than the factory gasket and just blocking the outside drain holes.
Are there drain holes in the interior or is it just filling the channel and overflowing into the passenger compartment? Lastly did you spray on an angle and it went between the fixed and moving panels?
Old Nov 6, 2012 | 06:17 PM
wag53's Avatar
wag53
Sliding Window Leak
On, it's in correctly, made sure of that and yes, I was shooting the water at an angle to the glass. It fills up the channel and overflows, that's why I was wondering about the drain holes, they are in the window( factory) and in the gasket but not through the gasket. It's like they are there but not punched out, does that make any sense?
Old Nov 7, 2012 | 01:31 PM
Brain's 97 Diesel
Aftermarket gasket, not always the same as factory. Punch holes, unless gasket is backwards. Good luck.
Old Jul 9, 2014 | 04:00 PM
madpogue's Avatar
madpogue
Excuse the necropost; any update on this?
So the bottom of the gasket should allow water to drain out of the channel? But where does that water go? Doesn't it go between the cab walls, then, or into the cab? Or is there a tube in there somewhere. We're running into the same thing, '95 F250 XLT SuperCab PSD, original slider window as far as we know. Good heavy shot from the garden hose fills the slider channel with water. We eventually get water in the padding that's stuck to the back side of the interior trim panel going across the back of the cab.
fetusgrinder
Ford Truck Parts for Sale
Apr 15, 2017 12:06 AM
madpogue
Jul 19, 2014 09:58 PM
66F250CS
Jun 11, 2013 10:58 AM
9d4
Feb 1, 2010 01:22 PM
tickletim2
Bronco II
Nov 30, 2006 07:12 AM
