Choke wiring
Old May 21, 2003 | 10:11 AM
paul739's Avatar
paul739
Exclamation Choke wiring
My 1983 2.8L ranger has lost power to the choke after the wire was dropped on a ground and sparked. I was wondering if anyone knows where the wire comes from or what could have been shorted out by this accident. The choke bimetal is good, but it takes way too long to open completely. Please advise.
thanks
Old May 23, 2003 | 11:23 AM
amp17757's Avatar
amp17757
Choke wiring
Hey, sorry it took so long to get to ya'. I have an '85. I would assume that the choke circuitry wouldn't have changed much, if at all, from '83 to '85. On the inside PASSENGER SIDE fender wall, there is an electronic control, that controls current to the choke heater. It is solid state (transistorized). So, if you accidentally shorted it out, it probably burned out, or was significantly damaged. It is a plug-in unit, thus I assume it can be purchased from a Ford dealer at least, if not an auto parts store. The solid state device is initially powered by the computer. After the engine & compartment warm up sufficiently, power THEN comes from a constant hot wire (hot all the time, engine on or off), to continue sending current to the choke heater to prevent it from closing too early & quickly, causing flooding & fouling out. If you replace this unit, but still have trouble, then the computer, or another device (fuse, fusible link, etc) may have been compromised. I would bet money that it is simply the solid state unit though. Stay in touch. Let us know how you do.
erik68
24
Oct 15, 2019 03:05 PM
Cienega32
Dec 22, 2011 06:54 PM
rob8210
Nov 16, 2008 03:24 PM
MTZBoeger
Electrical Systems/Wiring
Jan 28, 2004 03:46 PM
wiznewski
Sep 17, 2003 05:00 AM
