Boost help
Old Nov 5, 2012 | 11:26 PM
4CFarms's Avatar
4CFarms
Boost help
Simply put, im not very educated on the whole boost and what i should look for. But when im driving with no load, if i hit 70 on the highway im constantly at 5 psi, and when im on a grade it climbs to 10 psi. Is this in anyway bad, please educate me guys!
Old Nov 6, 2012 | 12:37 AM
stainlessstroker95's Avatar
stainlessstroker95
The highest you will see stock is around 17. Im no help on where you need to be while cruiseing though.
Old Nov 6, 2012 | 05:30 AM
427 fordman's Avatar
427 fordman
That sounds about right. Have you checked you boost at wot?
Old Nov 6, 2012 | 06:22 AM
fordman67's Avatar
fordman67
Mine is stock other than exh and 6637...if i hit it right and the trans does not shift prematurely i can get 20psi.
Old Nov 6, 2012 | 11:02 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
I also think is OK, you need a load and a hill to get a higher boost.
Old Nov 6, 2012 | 02:01 PM
fordpride's Avatar
fordpride
On a empty truck 3-5 psi in hwy. is normal on a climb it'll go up another 5-7 psi and a WOT you should be around 18psi. Checking for boost leaks and exhaust manifold, Uppipe leaks won't hurt.
derek0525
13
Jan 19, 2016 03:57 PM
diesel-fitter-bum01
23
Dec 9, 2009 05:54 PM
Bin Strokin
19
Jun 15, 2008 08:28 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
scalezy3b811
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 21, 2004 01:54 PM
