Loaded down and headed out!
I have a 32 ft TT, so I am thinking 4.30 gears will be in my future for the V-10, and then I need to address the 4R100, as it is bone stock, and original, so I don't want it to puke on me on the road...
Any thoughts would be greatly appreciated!
Thanks again for the insight on your trip, and hope that you are healing well!
Garry in Kodiak, Alaska
From everything I've ever known the way to keep a transmission happy and healthy is to keep it at the right temperature and use the right fluid. Possibly the most common mod to help with transmission cooling is to install the cooler from a 2003+ 6.0L diesel truck; this is the largest cooler available, and it bolts right in with minimal fuss. The downside is that it provides so much cooling that my transmission never got up to temperature when the Ex was unloaded, so I bought and installed the Derale kit in my signature. Here's the thread where I posted temperature data and how I installed it:
https://www.ford-trucks.com/forums/1...tallation.html
I also flushed the transmission using Mark K's flush instructions. Note that Mercon V is the correct fluid for this transmission, and I used genuine Motorcraft fluid that I was able to get at O'Reilly auto parts for less than $5/quart. Mark K also recommends Mobil1 full synthetic ATF, but that stuff was a bit spendy for me!
After towing with this truck I would have to say that 4.30s are a must if you plan on approaching or exceeding the max tow weight of 10,000 lbs. I exceeded it by 50%, and was very satisfied with how it handled the weight. But with the data on my scangauge it's pretty clear that it would not have held overdrive with 3.73s. On top of that you'd have 15% less grunt in first gear to accelerate from a stop with.
So if you service your transmission, add a 6.0l cooler, and add 4.30 gears you should be well set up to pull. And if you spend any time driving around without the trailer or cold weather I HIGHLY recommend the Derale thermostat kit.
ON edit:
Here's the link for the transmission flush article:
https://www.ford-trucks.com/article/...nsmission.html
I have an 05 EX with a 6.0L 3.73 gears, Rancho 9000, ProPride, Air Bags, Helwig. The whole rig weighs 21,500 lbs. I managed 13 mpg (US ) I often thought i would need more gear...like a 4:10.
ON edit:
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
So if you have a different gear ratio in the front compared with the rears, locking into 4WD will require the front and rear tires to spin at different speeds because even though the driveshafts are spinning exactly the same speeds the gearing is different between the two. So in a nutshell if you were to change the gears in the rears you would lose ALL 4x4 capability; shifting into four wheel drive would be catastrophic to your driveline unless you were on something very slippery, and in this event it would be uncontrollable.
So my truck has 4.30s in the front and the rear.
