Ex starting issue
Old Nov 7, 2012 | 11:30 AM
DavidDinsmore's Avatar
DavidDinsmore
Ex starting issue
I have a 2000 V10 ex. The past couple if days it been giving me some issues while trying to start. At times it will start fine like every truck should, but every now and then I turn the key and it starts to catch but quickly dies. Then it continually turns over. I apply pressure to the gas and it finally catches and runs fine after that. This problem has been getting worse over the past month. Whenever I start it I have to apply gas before turning the key so I know the engine will catch. I've already added fuel treatment and stp to clean fuel pumps but had no luck with that. Any ideas?
Old Nov 7, 2012 | 07:24 PM
BroncoRN's Avatar
BroncoRN
Check fuel pressure at valve on the fuel rail with key on.
Clean idle air control.
Change fuel filter.
Pull engine codes. -that'll gotcha started.
Old Nov 7, 2012 | 07:33 PM
DavidDinsmore
I went to autozone today an bought a fuel filter. Just need to get out and put it on. After that I'll see what else I can with the tools I have. I'm trying to avoid taking it to a shop because I'm a hands on person but sometimes there's no choice.
Old Nov 7, 2012 | 07:39 PM
BroncoRN's Avatar
BroncoRN
Autozone sells a great fuel pressure tester for fords with the Schrader valve. Good time to buy a good code reader too for OBDII vehicles. Search for IAC on here for where it is. Then clean it with carb cleaner.
Old Nov 7, 2012 | 08:41 PM
wpnaes's Avatar
wpnaes
https://www.ford-trucks.com/forums/1...r-r-and-r.html
Old Nov 24, 2012 | 08:22 PM
miked1962's Avatar
miked1962
put that fuel filter on it fixed my 2000 right up and I was having the same problem
Old Nov 24, 2012 | 11:18 PM
DavidDinsmore
Mine has also been running a lot smoother, I also bought a fuel treatment called zmax, seemed to work wonders, never felt my truck run so smooth
racin
1997 - 2003 F150
Apr 5, 2016 07:10 PM
Klr44
May 13, 2014 10:36 AM
egalaxie
Oct 27, 2008 10:37 PM
truckfarmingcanuck
Nov 21, 2006 06:12 PM
brian931
1983 - 2012 Ranger & B-Series
Nov 30, 2004 06:54 PM
