Headlights not working
Old Nov 4, 2012 | 07:43 PM
NHstroker's Avatar
NHstroker
I took out the isolation module for my plow along wiht all the wiring because i bought the truck with no plow and i dont plan on plowing with it, also just trying to neaten things up, but i was wondering if the module is not there anymore where do the headlight wiring harnness's plug into to get power?
Old Nov 4, 2012 | 07:56 PM
glovemeister's Avatar
glovemeister
Your gonna have to trace and splice them back together if they cut into the wires instead of adding extension plugs.
Old Nov 4, 2012 | 08:07 PM
NHstroker's Avatar
NHstroker
What do you mean? each headlight has plug that was plugged into the isolation module. Where is the stock plug to plug them into or am i gunna have to change the harness
Old Nov 4, 2012 | 08:21 PM
glovemeister
What is plugged into your headlights? If they had an adapter harness for the isolation module just plug both sides of the truck plug into the lights and it should work. If you don't have those you will have to cut the isolation plug out and wire in new one from your type of truck from the junkyard.
Here is the stock diagram from the shop manual: http://www.thedieselstop.com/faq/949...e=stjs73br.htm
Old Nov 4, 2012 | 08:26 PM
NHstroker's Avatar
NHstroker
Where do the lights plug into to get power
Old Nov 4, 2012 | 08:35 PM
NHstroker's Avatar
NHstroker
http://i1306.photobucket.com/albums/...ckbarry275.jpg
thats what plug theres ones for left and right headlights
Old Nov 4, 2012 | 08:36 PM
glovemeister
I don't think I have one of those in my truck. It comes from switch to headlights with wire the entire way. Then at the ends where it plugs into the lights it has a standard 3 or 4 pole plug.
Old Nov 4, 2012 | 09:00 PM
NHstroker's Avatar
NHstroker
so near the switch is where it would plug into to get power?
Old Nov 5, 2012 | 11:28 AM
NHstroker's Avatar
NHstroker
I got it all fixed thank you glovemeister for the help
J&J09
2004 - 2008 F150
Feb 20, 2012 07:48 PM
AJHEATING
Jan 22, 2012 02:41 PM
jetdoc
13
Oct 30, 2009 04:11 PM
Mr. X
2004 - 2008 F150
Aug 26, 2007 12:50 PM
nhawki00
Feb 15, 2005 07:08 PM
