1978 - 1996 Big Bronco
ABS Problems
Old Nov 4, 2012 | 06:17 PM
autochefc's Avatar
autochefc
ABS Problems
ABS Problems<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
1989 bronco 4x4 manual tranny <o></o>
When I Break hard my abs light and break light come on and stay on and when the system is restarted they go off so I just figured is was a bad rear break sticking (because on one outing I had the passenger side break start to smoke) upon inspection of breaks they look ok I checked the sensor on top of the differential and cleaned the connector looks ok. When I tried to pull the codes about the abs by grounding the orange and black wire by the parking break my abs light does not give me any codes? So how do I pull the codes? Also there is a rabs connector in the engine compartment next to my engine code test can you pull abs codes from this? If so how? I am going to pull the plate on the differential to see if there is any damage there it also looks like I am getting some type of lubrication spraying the floor of the cargo area above the differential? Thanks <o></o>
esbrian
Jul 6, 2017 06:07 PM
_Me2_
Mar 9, 2013 10:11 PM
touchupman
1983 - 2012 Ranger & B-Series
Aug 25, 2006 02:44 AM
79shovelhead
Mar 26, 2006 10:55 PM
