please help! big knocking engine noise
Old Nov 4, 2012 | 02:52 PM
IDM1's Avatar
IDM1
I dropped my car(2003 explorer XLS) for a brake pad work at an auto shop. but when I went to pick it up, the engine made big knocking noise when starting. the mechanic told me seems the engine having problem. he was shock too because he admitted the car was fine when I dropped it. he didn't do anything except the brake work and top of some oil(I told him to check the coolant and oil level). I towed it to dealer and was told the engine is bad, I need a new engine. he didn't give exact diagnosis, said that will cost more than $900. he also said the mechanic seems didn't do anything wrong.
the car doesn't show any other symptom except the noise, does anyone know what might be the problem? I want to try whatever I can before rebuild the engine.
Thank you very much for any help. since it is not drivable now, it is hard for me to get it checked elsewhere.
Old Nov 8, 2012 | 02:17 PM
SBV45's Avatar
SBV45
Did you have to pay the dealer a diagnostic fee? I would expect a better explanation from the dealer other than the "engine is bad". There could be lots of reasons for the knock (none of them good). Is your engine a V6 or V8? I would ask for a written diagnosis. A new engine for $900 seems a little low. Is the mechanic talking repair your existing engine, a new engine, or rebuilt engine.
Old Nov 8, 2012 | 02:48 PM
IDM1's Avatar
IDM1
diagnosis fee is around 45~90(I didn't go there yet, don't know exact charge). he told me the engine is bad, if I want to know more, have to spend more than $900 for diagnosis(he didn't tell me that at the beginning, though I made it clear I want to know what is wrong). he quote a new engine of $5000.
please see more details here
http://www.explorerforum.com/forums/...d.php?t=373665
Old Nov 12, 2012 | 07:50 PM
marragtop's Avatar
marragtop
I suspect the $900 estimate is just to have them tear the engine down to see what the problem is. You dont indicate which motor you have, but your problem could be timing chain(s) related. Fairly common problem and expensive.
Old Nov 14, 2012 | 10:10 AM
caseys's Avatar
caseys
xxxxxxxxxx
Reidicus
Mar 24, 2008 06:06 PM
lee3
6.4L Power Stroke Diesel
22
Jan 13, 2008 11:14 AM
GavinStevens
2004 - 2008 F150
16
Jun 30, 2006 03:16 PM
JnJ
1983 - 2012 Ranger & B-Series
Aug 3, 2003 11:21 PM
norlfran
Jan 16, 2001 02:07 PM
