I have a 1999 F-250 with a V-10
The problem I am having is the PCM fuse has failed. This happened while I was driving. I noticed that the volt meter went to zero and then the truck died.
Since the pcm and the fuel pump share a circuit I have eliminated the possibility of the fuel pump causing the problem. After replacing the fuse, as soon as I turn the key to on it fails again
Is it possible that the pcm is bad?
If you know your way around a DVOM you can check the wiring harness for problems. If it is fine then it probably is the PCM. If you don't have the right tools or knowledge it is probably best to pay a good independent shop to find and fix the problem for you.
