Modular V10 (6.8l)
please help
Old Nov 4, 2012 | 09:56 AM
sghudson1's Avatar
sghudson1
please help
I have a 1999 F-250 with a V-10
The problem I am having is the PCM fuse has failed. This happened while I was driving. I noticed that the volt meter went to zero and then the truck died.
Since the pcm and the fuel pump share a circuit I have eliminated the possibility of the fuel pump causing the problem. After replacing the fuse, as soon as I turn the key to on it fails again
Is it possible that the pcm is bad?
Old Nov 4, 2012 | 10:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it is possible. It is much more likely that there is a short in the wiring to the PCM.
Old Nov 4, 2012 | 10:07 AM
sghudson1's Avatar
sghudson1
Is there a way to determine if its the pcm or a short?
Old Nov 4, 2012 | 11:03 AM
Mark Kovalsky
If you know your way around a DVOM you can check the wiring harness for problems. If it is fine then it probably is the PCM. If you don't have the right tools or knowledge it is probably best to pay a good independent shop to find and fix the problem for you.
Old Nov 4, 2012 | 11:33 AM
BigPigDaddy's Avatar
BigPigDaddy
It is possible the PCM is bad. Like Mark said, there could be short in the harness.
Old Nov 4, 2012 | 06:46 PM
SDV10's Avatar
SDV10
I have a spare PCM Part number FXU2 i believe. Where are you and will this work for him?
Old Nov 4, 2012 | 07:07 PM
BigPigDaddy
He's in NY. If you both have auto or stick transmissions it may work.
Old Nov 4, 2012 | 07:10 PM
SDV10's Avatar
SDV10
It is auto
Old Nov 4, 2012 | 07:11 PM
SDV10's Avatar
SDV10
Your approval on my 'no Mopar' avatar is still waiting
Old Nov 4, 2012 | 08:18 PM
BigPigDaddy
Approved!
Old Nov 5, 2012 | 08:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Probably the easiest way to diagnose this is to start unplugging things. Disconnect the harness from the PCM and see if the fuse still blows
If it doesn't that doesn't mean the PCM is necessarily bad, but if it still blows with the PCM out of the loop, that does narrow it down a lot.
wrench191
Modular V8 (4.6L, 5.4L)
Nov 17, 2017 06:54 PM
NovaNewfie
1997 - 2003 F150
Mar 9, 2014 10:04 AM
CAL2003PSD
Sep 11, 2009 08:40 PM
REDONE97
Electrical Systems/Wiring
Oct 30, 2005 09:55 PM
buff4
Jul 22, 2004 11:42 PM
