clunking sound
Old Nov 2, 2012 | 07:07 PM
tajon's Avatar
tajon
clunking sound
when I turn the wheels to full lock, either right or left, I hear a clunking sound. Usually pulling into parking spots, into the driveway, etc.....but only going forward, not in reverse.
Where do I start?
Old Nov 2, 2012 | 08:01 PM
sammie0126's Avatar
sammie0126
Where do I start?
Ball joints and sway bar bushings, search for both on the excursion forum and you will find plenty of posts.
Old Nov 2, 2012 | 08:09 PM
BroncoRN's Avatar
BroncoRN
What would a clunking? Noise be going over uneven ground?
Old Nov 2, 2012 | 10:55 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
This is usually the sway bar bushings in the links. They attach the bar (attached to your axle) to the frame up above. The bolts that go through the bushings have also been known to work themselves loose and need re-torquing.
If your ball joint is clunking, you are in trouble! But it could be possible...
Old Nov 2, 2012 | 11:08 PM
EXv10's Avatar
EXv10
Sounds like U-joints to me. When you are rolling? (You said turning).
Old Nov 3, 2012 | 06:50 AM
golfmedik's Avatar
golfmedik
My bet will be the sway bar end links. Mine have popped on and off for 184k miles! Just this week I bought metric, high grade bolts(from Fastenal) to replace the junk OEM ones so I can torque them at a higher setting.
Old Nov 3, 2012 | 08:22 AM
tajon's Avatar
tajon
Yes its when rolling, not just turning the wheel. The closest thing it resembles is when you're cutting the wheel at full lock in 4wd on dry pavement.
Old Nov 3, 2012 | 11:23 AM
EXv10's Avatar
EXv10
Do you put them in yet? You might have to take them back as tightness isn't the answer. I am getting mine today and might do a thread on it.
Old Nov 3, 2012 | 11:25 AM
EXv10's Avatar
EXv10
Pulling into those places on level ground? Are the hubs locked?
Old Nov 3, 2012 | 11:26 AM
EXv10's Avatar
EXv10
double post
catscratch
Sep 7, 2012 08:09 AM
Jager
17
Jan 10, 2011 01:10 PM
jim6liter
Jun 11, 2009 07:53 AM
viperbluelx
Dec 3, 2008 06:29 AM
01powerstroke01
36
Apr 8, 2008 11:29 PM
