Bronco II Ford Bronco II
A4LD shifting problems
Old Nov 1, 2012 | 08:52 AM
kymadan's Avatar
kymadan
When I drive, my Bronco II stays in first gear for a really long time. Once the transmission warms up it will shift correctly as long as it is hot. As soon as it cools down, same problem again. I have been told it is the torque converter, modulator valve, gasket for the filter, and/or dirty fluid. Transmission has just been installed on it and it has new filter and fluid. As far as I remember, transmission was fine when it was in my other Bronco II. I do remember buying a modulator for that transmission as well.
Anyone have any clues as to what this might be? I need my vehicle back!
Old Nov 15, 2012 | 06:59 PM
fl1a's Avatar
fl1a
If it were the gasket for the filter or similarly, low fluid, the transmission will just quit working. I have had that to happen and have had the transmission fail completely. I've not had a failure to shift with mine. If you still have the problem, try posting your question on the Ranger forum also, as the running gear is common between the two vehicles.
kuli
1983 - 2012 Ranger & B-Series
Aug 24, 2015 02:26 PM
TODD SIEBEN
32
Sep 29, 2009 10:56 AM
mrmilkme
Mar 4, 2006 01:47 AM
Lykos
Jan 12, 2006 07:45 PM
jakemahn
Bronco II
18
Apr 28, 2005 11:29 AM
