Torque Converter
Old Oct 31, 2012 | 01:29 PM
MavSprint's Avatar
MavSprint
Torque Converter
Have a '70 F100 project that will get a 5.8L/351W engine out of a '95 F150 and a 4R70W transmission out of a '00 F150. The engine with aftermarket heads, intake, carb, mild cam and headers should make about 425 FWHP. Use will be daily driver with an occasional trip to the strip just to time it. Rear end gears will be 3.73.
I'd like to find a reasonably priced torque converter with about 2400 stall. Seems like I read that some of the stock converters for that transmission were in that stall range.
Anyone have a recommendation?
Old Oct 31, 2012 | 07:31 PM
wyoming4x4's Avatar
wyoming4x4
hughes performance tranny's.
give hughes a call. have had some really good luck over the yrs with these guys. what exactly is you rpm range and what cam specs will really help out on the converter selection. with a 3.73 gear will put a lot of pressure on you stator in converter. what weight? need to know all these question for any decent transmission/converter shop. if they don't ask these questions your dealing with wrong shop. good luck and keep us informed. have had some bad luck with a converter shop and they are suppose to be a good company. hughes hasn't blown up and very pleased in my application.
Old Oct 31, 2012 | 08:48 PM
MavSprint's Avatar
MavSprint
I'll give Hughes a call but I'm hoping to avoid the cost of a custom converter. Don't have the cam specs yet but I'm not looking for a radical cam. Streetability is the priority. Weight should be about 3600-3800 lbs I think.
I was looking at something like this Hughes Performance Street Master Torque Converters 53-25L - SummitRacing.com but if there's a stock converter with about 2400 stall maybe it would be less money.
Anyone know where to find stall specs for the stock 4R70W converters?
Old Nov 7, 2012 | 01:04 PM
MavSprint's Avatar
MavSprint
Good Customer Service
I sent a question to Hughes Performance asking what nuts/studs are used to bolt their torque converter up to the flex plate. Here's their response. Makes me feel good about their customer service.
Hello Jim,
Thank you for submitting a contact form with Hughes Performance. The 53-25L torque converter features a 3/8-24 fine thread on the converter studs. I will be happy to send you a set of nuts. Please send me your mailing address. If you have any other questions or concerns, please feel free to contact me at any time. Thank you for your interest in Hughes Performance!
Pete Nichols
Sales Manager / Tech Support
Hughes Performance
800-274-7223 Ext. 209
602-889-3621
www.hughesperformance.com
Old Nov 7, 2012 | 03:46 PM
wyoming4x4's Avatar
wyoming4x4
yes they are consistant on service.
Been very pleased with them over the yrs. had a bad run in with TCI and was very expensive$$$$$. i used a xtm43 converter for a 460 and had a few upgrades for my paticular situation. Really like the stator thats in a xtm series converter. i have big tire and hrspwr situations and getting it all to work together reliably was the trick. they ask the right questions and excellent tech over the yrs.
Old Aug 22, 2013 | 10:37 PM
Kenric Harmon's Avatar
Kenric Harmon
1997 expedition has rev but wont go forward
Old Aug 23, 2013 | 12:16 AM
stuart1's Avatar
stuart1
Start your own thread. Makes life much easier.
Bimmerboy1989
1978 - 1996 Big Bronco
Feb 13, 2007 01:49 PM
bigpowerstroke
Jan 4, 2007 09:56 PM
dsmith_78
Jan 17, 2004 11:07 PM
Sunny_in_hollister
Nov 14, 2002 08:59 AM
