Third brake light.
Old Feb 19, 2000 | 11:45 AM
Katt's Avatar
Katt
Third brake light.
I would like to know if anyone has added a third brake light to their truck? Is there one that will go in with the cargo ligh(So I can have both the cargo and brake light?)
Please let me know!
Thanks
Old Feb 19, 2000 | 10:53 PM
tyleraa's Avatar
tyleraa
Third brake light.
The later model F-series trucks had a 3rd brake light stock. Unfortunately I think that Ford made the entire assymble a different size in those years. The cab is still the same though and if you wanted to buy a lighting assymbly from Ford I suspect that it would work. Drilling may be required... As for the wiring--there should be a wire in the harness under the driver side that powers the brake lights and/or one that powers trailer brake lights that you can tap into. Remember to seal your connection so that it won't be a liability in the future. If you want there is probably a simple way to wire the 3rd light directly from the stoplight switch on the brake pedal but I can't tell you right off how to do it. I think you would use it as you hot connect. Get a Chiltons and check out the diagram for chassi wiring before you get too into the project.
Old Feb 20, 2000 | 01:31 PM
PAUL_2's Avatar
PAUL_2
Third brake light.
Old Feb 20, 2000 | 07:02 PM
Katt's Avatar
Katt
Third brake light.
Yeah, I know how to wire it, I just don't know what light assembly will fit in the space. I guess I will measure and look around. Thanks!
Brian Ski 44
Apr 25, 2015 01:13 PM
fatforty
Feb 20, 2015 06:44 PM
F239141
WTB - Parts & other
Dec 28, 2014 04:58 PM
BarnieTrk
1983 - 2012 Ranger & B-Series
Sep 18, 2014 07:20 PM
