Won't start just clicks
Old Oct 30, 2012 | 12:29 PM
rocman01's Avatar
rocman01
I have a 97 F250 Powerstroke and when I try to start it I hear rapid clicks in the Dash, when I turn the key to start it chugs but wont start. If I keep the key in the run position and arc the posts on the starter relay it starts up and runs just fine. I replaced the starter relay thinking that would solve the problem, but it didn't. The shift lever is solid and it doesn't help to wiggle it or put in neutral. Any ideas? <!-- / message -->
Old Oct 30, 2012 | 12:38 PM
blageurt's Avatar
blageurt
Check batteries and all connections ..... and If good , it could be the Solenoid ON the Starter Itself....so you need to remove the starter and get it tested.....
Old Oct 30, 2012 | 12:48 PM
rocman01's Avatar
rocman01
Even if it starts strong by arcing the posts on the starter relay?
Old Oct 30, 2012 | 12:57 PM
Hussler's Avatar
Hussler
There is a small wire on the starter relay (fender) that just pulls off. When you turn the key to START that wire goes to 12 volts pulling the relay in. You can test the relay by unplugging the wire and jumping the terminal (where the wire was plugged into) to battery plus. Just be careful to have the truck in neutral or park. If it works then there is a problem with the "start" wire and we can go from there.
Old Oct 30, 2012 | 01:01 PM
blageurt's Avatar
blageurt
Sorry I did not read the part about shorting the relay terminals...my bad...
Old Oct 30, 2012 | 01:02 PM
rocman01's Avatar
rocman01
Thank you, I'll try that tonight when I get home.
Old Oct 30, 2012 | 08:51 PM
rocman01's Avatar
rocman01
I jumped the terminal that had the small wire and the truck started. It will start both ways. Large terrminal to large terminal, and positive terminal to the small terminal
Old Oct 30, 2012 | 08:57 PM
madpogue's Avatar
madpogue
Do you hear the rapid clicks with the key in RUN, or in START?
Just for grins, put it in Reverse or Drive (it's an automatic, right?) and confirm that it does NOT try to start then. That is, no noise at all. That will rule out the NSS.
Old Oct 30, 2012 | 09:01 PM
Hussler's Avatar
Hussler
Maybe a bad ignition switch, but I doubt it? The wire you removed (small one) from the starter relay, if you can use a volt meter and measure the voltage when someone turns the key to START. It, of course, should read battery voltage to power the relay. You might just have a bad connector that plugs into that relay, more than likely. Needless to say the relay is OK.
Old Oct 30, 2012 | 10:17 PM
rocman01's Avatar
rocman01
looks like I had it all wrong. I followed the clicking sound and found a relay under the dash that had worked itself loose. snapped it back into place and everything is working great. Thanks for all your help, It helped me to narrow down the problem one item at a time.
Old Oct 30, 2012 | 11:09 PM
madpogue's Avatar
madpogue
Must be something aftermarket, or perhaps factory RKE.
Old Oct 31, 2012 | 10:10 AM
rocman01's Avatar
rocman01
It look's factory. Thanks again for your imputs. Once I ruled out problems under the hood, I started looking under the dash and found it.
FordLou
1997 - 2003 F150
22
Nov 1, 2019 06:39 PM
kirbykoon
Feb 12, 2013 08:45 AM
knapikmichael
May 3, 2007 03:57 PM
Longneck
Electrical Systems/Wiring
22
Oct 16, 2004 08:12 PM
