1995 5.0 wont start
Old Oct 30, 2012 | 10:13 AM
FordNFl's Avatar
FordNFl
1995 5.0 wont start
207,xxx e4od. prior symptoms, occasionally took a few seconds of cranking to start. Cel light for the first minute or so of driving. Always ran great.
I lost control of the truck and ran through about 6" of water. Never stalled or missed then or the rest of the ride home. the next day it started ran for 5 seconds stumbled and died. Hasnt started since.
Found moisture in the dizzy. Marked its spot removed it brought it inside to let it dry out. After reassembly checked spark, present but weak. Checked coil, failed the ohm test. Replaced it. Soundd like its trying now but still wont start. Fuel pressure is at 38 pounds within range. getting anoid tester today to ensure injector signal.
All ideas and help would be much apreciated.
Old Oct 30, 2012 | 10:36 AM
subford's Avatar
subford
Does the fuel pumps run all the time the key is on with the engine not running?
I have a bad feeling on this one that you may have lost your computer.
Old Oct 30, 2012 | 10:47 AM
FordNFl's Avatar
FordNFl
one time when I released the key from cranking it over it ran for a second or two. Another time it wouldnt come on. Other than those two instances it primes the system as usual. is there any way of checking the computer? Thank your for the suggestion.
Old Oct 30, 2012 | 11:11 AM
subford's Avatar
subford
Sound a little inconsistent.
I was thinking you may have got water into the computer plug.
I would pull the computer and open it up and see what you have.
You may see some burnt parts or leaky electrolytic capacitors.
Old Oct 30, 2012 | 11:17 AM
FordNFl's Avatar
FordNFl
Ok I will pull it when I get off work and let you know what I find. Thanks so far.
Old Oct 30, 2012 | 07:33 PM
FordNFl's Avatar
FordNFl
Ok got the computer out. outside is covered in white corrosion looking stuff, and a little bit of rust. inside looks ok no burnt spots, doesnt smell burnt. However it does have a slight battery acid kinda smell. Possibly the capacitors you mentioned. Also the connector was full of water. I believe the computer is the culprit as you suggested. I will try to find a suitable replacement this weekend at the local pull and pay. thank you so far. I will let you know the results.
Old Oct 30, 2012 | 07:55 PM
subford's Avatar
subford
If it is not burnt I would dry out the plug and fill it with dielectric grease and try it again.
You do not have to install the computer just plug it in.
Old Oct 30, 2012 | 08:02 PM
FordNFl's Avatar
FordNFl
the computer is in the house drying out. I will try as you suggested when I get off work tommorow and let you know how it goes.
Old Nov 1, 2012 | 11:25 AM
FordNFl's Avatar
FordNFl
Didnt get to work on the truck last night. Hopefully I will tonight. Ill keep updating and let you know how it goes.
Old Nov 1, 2012 | 06:03 PM
FordNFl's Avatar
FordNFl
Got it running. Water in the fuel tank. thanks for your help. Do you know how I can upload a picture of the truck?
Old Nov 1, 2012 | 07:03 PM
Lead Head's Avatar
Lead Head
You can upload a picture to your "Garage" on here, or to photo hosting sites such as imgur.com, tinypic.com, photobucket.com, etc..
Wynn93
Nov 7, 2012 08:22 AM
Bowtie95
Sep 2, 2012 01:25 AM
redwolfhopw
18
May 20, 2008 08:32 PM
hondo2380
Nov 2, 2007 06:28 PM
fasteddie
Feb 24, 2003 11:01 PM
