Introduction & Decode Request
Old Oct 29, 2012 | 07:06 PM
kc0kdh's Avatar
kc0kdh
Hello all. I'm Lance a new member and recently acquired a '66 F-100 starter that's in really great shape for a starter project. Mechanically sound, mostly straight, and everything important works!
I'm just starting to figure out what direction I want to go with it for a project and would greatly appreciate it if someone could decode my warrantee info for me. I've been doing some digging and have managed decoding some of it, but I'd appreciate a sanity check and a filling if of the missing info.
Warantee Code F10AR764342
F10 F100 - 2 wd
A 240 cid 6 cylinder
R San Jose, CA
764342 Oct 1966
W.R. - 29 = ????
Color - M = Wimbledon White
Model - F100 = It's not a Falcon :P
Body - N81 = ????
Trans - C = 3 Speed light duty (any other details available?)
Axle - 09 = 3:70 (any other details available?)
GVW - 5000 = I assume gross weight
HP - 129 = I assume rated HP
RPM - 4000 = I assume max RPM
DSO - 74 = ????
Thanks in advance. Looking forward to chatting with everyone.
Lance (kc0kdh)
Old Oct 30, 2012 | 05:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN: F10AR764342 // W.B. 129 / COLOR: M / MODEL: F100 / BODY: N81 / TRANS: C / AXLE: 09 / MAX GVW: 5000 / CERT. NET HP: 129 / RPM: 4000 / DSO: 74
Welcome to FTE
F10 = F100 2WD
A = 240 1V I-6.
R = San Jose CA Assembly Plant.
764342 = 1966, assembled October 1965.
129" Wheelbase.
M = Wimbledon White.
F100 2WD, 5,000 lbs. GVWR
N81: N = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81A Standard Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
09 = Ford 9" Rear Axle / 3.70-1 / no Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
74: Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Oct 30, 2012 | 10:12 AM
arctic y block's Avatar
arctic y block
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Oct 30, 2012 | 07:20 PM
kc0kdh's Avatar
kc0kdh
NumberDummy, thanks much for the decode.
Arctic, thanks for the welcome!
fereo0
May 29, 2014 11:24 AM
loquito
20
May 25, 2014 10:22 PM
Squirrel987
16
May 14, 2014 03:29 PM
tthurman40
Dec 30, 2013 01:17 PM
th3 gunslin9er
Aug 14, 2013 06:15 PM
