engine seized up?
Old Oct 29, 2012 | 02:18 PM
tjustice's Avatar
tjustice
engine seized up?
Driving along about 60 mph truck dies try to restart engine wont turn over shakes truck and thats all she will do..
Was doing so good after new head bolts gaskets and things.....any suggestions...
Old Oct 29, 2012 | 02:21 PM
mustang_309's Avatar
mustang_309
Any coolant loss? If so it could be hydro locked with coolant in the combustion chambers.
Old Oct 29, 2012 | 02:57 PM
tjustice's Avatar
tjustice
Nope. its full....
Old Oct 29, 2012 | 04:01 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Pull the alternator(accessory) belt and retry.
Old Oct 29, 2012 | 05:18 PM
tjustice's Avatar
tjustice
<table class="tborder" id="post12426481" align="center" border="0" cellpadding="6" cellspacing="1" width="100%"><tbody><tr> <td class="thead"> #4 (permalink)
Today, 05:01 PM
</td> </tr> <tr> <td class="alt2" style="padding:0px"> <table border="0" cellpadding="0" cellspacing="6" width="100%"> <tbody><tr> <td class="alt2"></td> <td nowrap="nowrap"> Rusty Axlerod
Garage is empty, add now </td> <td width="100%"> </td> <td nowrap="nowrap" valign="top"> Join Date: Feb 2011
</td> </tr> </tbody></table> </td> </tr> <tr> <td class="alt1" id="td_post_12426481"> Pull the alternator(accessory) belt and retry.
Putting the frontend back under my 01 350 so I can get it in the garage then will try it. Be a little bit.
</td></tr></tbody></table>
Old Oct 29, 2012 | 07:39 PM
BLADE35's Avatar
BLADE35
Wonder if a Injector oring went and Dump fuel into the Cylinder
Old Oct 29, 2012 | 08:27 PM
tjustice's Avatar
tjustice
Ok, finally got spare truck up and going and 05' into the garage. Took the fan belt off nothing still the same clung and nothing happens....Guess will sleep on it and start elimination process in the morning.
Old Oct 30, 2012 | 06:31 AM
tjustice's Avatar
tjustice
Morning has came and hooked up the AE and Scan gauge 2 up neither shows the first code....Guess its disassemble time to see what the deal is....
Old Oct 30, 2012 | 06:53 AM
bismic's Avatar
bismic
You might want to pull the glow plugs and see if you can get it to rotate by hand or get it to crank (but stay away from the "line if fire" - fluid can shoot out from the glow plug hole w/ a lot of force).
Old Oct 30, 2012 | 08:09 AM
69cj's Avatar
69cj
Had a Cat mechanic killed on a job out here doing that. Fuel went thru his eye into his brain. Lots of pressure.
Old Oct 30, 2012 | 09:09 AM
tjustice's Avatar
tjustice
Don't guess I will be doing that.....
Old Oct 30, 2012 | 10:11 PM
bismic's Avatar
bismic
you can always try rotating it by hand.
Old Oct 31, 2012 | 05:29 AM
tjustice's Avatar
tjustice
Bismic.....I am going to do glowplug and rotate....Back on shift today will start back Thursday morning when get home.....
Old Nov 1, 2012 | 10:16 AM
tjustice's Avatar
tjustice
You guys look please look at my Hydro-lock thread.....I think found the cause of the problem,,,,posted pic....also will be just using that thread..
bizzj
Dec 15, 2014 08:18 PM
FirePrincess9555
Oct 2, 2012 06:48 PM
79 f-150 guy
20
May 4, 2011 12:39 PM
Mr. Bob
Dec 19, 2006 07:44 PM
