Camshaft Selection
Old Oct 28, 2012 | 09:37 PM
Brown_Jonathan89's Avatar
Brown_Jonathan89
Camshaft Selection
Ok I Have an 84 F250 2wd With A T18 And 3.73s And I Would Like To Upgrade My Cam For a Lil More Bottom End And I Dont Know Muchs About The Aftermarket Stuff What Should I Look For?
Old Oct 30, 2012 | 06:40 AM
baddad457's Avatar
baddad457
For what you've got, stick with the "RV" style cams. Somthing no more agressive than Comp's 268H
Old Oct 30, 2012 | 09:03 AM
Brown_Jonathan89
Thats Along The Lines Of What I Was Thinking I'm Just Not Good When It Comes To Figuring Out All The Durations And Lift And All That
Old Oct 30, 2012 | 10:04 AM
Conanski's Avatar
Conanski
Is your motor all stock? Is it a factory 4bbl motor or not? If it is it already has a pretty good RV cam in it but the heads its wearing are smog era with massive combustion chambers so static compression is down around 8.3:1, combine that with the stock manifolds and exhaust and that's why the motor feels weak. For a hugh boost in TQ swap on some late model E7TE heads from an '87+ truck motor or better yet GT40s from a '96-97 Explorer 5.0 and add longtube headers, that'll bring compression up to 8.8-9.2:1 and along with the much improved cylinder scavenging provided by the longtubes you'll have tons more grunt from idle up.
Old Oct 30, 2012 | 08:33 PM
Brown_Jonathan89
Yea it's all stock with A 2 barrel carb
Old Oct 30, 2012 | 09:35 PM
Conanski's Avatar
Conanski
OK then it has low compression smog heads and a tiny cam, so put heads and a 4bbl carb and intake on the list and pick up a Comp Cams 35-234-3 cam and lifter set in the meantime.
79FordBlake
Aug 16, 2017 09:45 PM
87thhunter
Jan 2, 2016 05:04 PM
Nova406
Nov 21, 2014 08:23 AM
jpeckham
Jan 17, 2013 11:01 PM
Bulldawg1081
May 23, 2008 07:36 AM
