look at your vacuum hoses under the hood. They get cracks or brittle from over the years. You can spray throttle body cleaner around them and find it fast. Also check the one way valve for leaks. One side is black the other is white or clear.
OP has a diesel, the brake cleaner trick wont work.
I have good pump....the door between the fan and the heater box opens and closes.....when you turn the directional **** on......
Jon
Check the heater directional water flow valve next to the ac box. Its a metal valve with your heater hoses on it. make sure the.vacuum hose is closing and opening.
Also check for leaks at the ***** on the back of the selector switch.
I just went through this with my '99. I'm not sure how the diesel system works, but my line broke at the vacuum reservoir behind the evaporator housing. I ran a new reservoir under the hood and connected in to the vacuum line behind the control in the dash.
