Transmission HELP needed.
Old Oct 26, 2012 | 03:43 PM
John & Old Ford's Avatar
John & Old Ford
I am currently assembling the Transmission Output Shaft Bearing Retainer onto the Transmission Case, and have noticed that the “face” of the Transmission Case where the Transmission Output Shaft Bearing Retainer attaches to has 8 (eight ) holes and the Transmission Output Shaft Bearing Retainer only has 7 (seven).
When I place the Transmission Output Shaft Bearing Retainer, onto the transmission case, that eight hole on the transmission case is slightly covered by the speedometer assembly.
I took pictures of this section before disassembling, and I don’t see anything that could be missing.
The old (Broken)Transmission Output Shaft Bearing Retainer on the top pic also has seven holes.
[IMG]http://i1062.photobucket.com/albums/t498/1949-F6/TransmissionAssembly1.jpg[IMG]
Old Oct 26, 2012 | 04:30 PM
4tl8ford's Avatar
4tl8ford
Does the hole behind the speedo go all the way thru the case? - If not no problem - There are several different types of retaines that can fit these as the application call for.
If it does go all the way thru find or make a plug that you can Loctite in it
Old Oct 26, 2012 | 05:13 PM
John & Old Ford
I beleive it does not go all the way, but will double check. So there is retainers that have 8 holes and the case is made to fit these retainers with eight holes?
Thanks.
Old Oct 26, 2012 | 06:03 PM
4tl8ford's Avatar
4tl8ford
Thanks.
Could be 4,5,6 etc holes depending on what, when, where and how.
GeorgeL
Apr 25, 2019 11:20 AM
WhoIsJohnDoe
Aug 18, 2012 07:46 PM
kkken22
Feb 19, 2010 02:54 PM
Para045
Oct 13, 2007 09:55 PM
BroncoCarl
1966 - 1977 Early Broncos
Jan 26, 2004 04:06 AM
