Back Again
Old Oct 26, 2012 | 01:32 PM
MohaveMan's Avatar
MohaveMan
Back Again
Hi Guys, well I'm back with another problem. I need to find out how to replace the ignition cylinder and keys on my 1984 F 150. The cylinder locked up and I had to take a BIG set of channel locks to get it to turn and shut the motor off and now, of course, it won't turn at all. I need to find out how to remove the old one and install a new one. Do I have to pull the steering wheel or is there this elusive pin hole where I stick a paper clip in there and take the cylinder out and insert the new one ? Would really appreciate any help. You guys were so helpful on my dual gas tank switch that I knew you would know how to do this. Thanks in advance for any help. Steve
Old Oct 26, 2012 | 01:52 PM
smashclash's Avatar
smashclash
there should be a pin hole near the cylinder underneath it. you'll need to turn the key and put it in a sweet spot and then push in (probably need something heavier duty than a paper clip) and it should slide out. but if you used channel locks to turn it you may have damaged it and have a hard time.
if you ever have a problem like that again it's best to pull the wire coming from the coil on the distributor. that will kill the engine. then disconnect the negative on the battery so it doesn't get depleted. then you can dig into the cylinder itself.
Old Oct 26, 2012 | 02:14 PM
Ken Blythen's Avatar
Ken Blythen
It needs to be in the 'run' position to remove/install.
Old Oct 26, 2012 | 02:22 PM
MohaveMan's Avatar
MohaveMan
Back Again
Thanks for the help/advice guys. Will try to find the "pinhole". Thanks again !!
Old Oct 27, 2012 | 08:24 PM
ctubutis's Avatar
ctubutis
I'm sorry I missed this when you first posted it, was on the highway.
You probably don't need this by this time, but there are two entries for this procedure in the Sticky; here are the official procedures as per Ford:
Originally Posted by ctubutis
The official procedure in the factory shop manual is equally as barbaric (although procedures are different for tilt & non-tilt):
DieselCamper
24
Oct 6, 2017 02:08 PM
Timwolve
Jan 5, 2014 08:21 AM
march
20
Jan 2, 2014 07:46 AM
Flat 'n Fat
Apr 6, 2011 10:24 PM
zuesman961
Feb 20, 2001 12:20 PM
